News Nvidia, Pegasys announce CUDA support for TMPGEnc
Discussion in 'Article Discussion' started by Tim S, 25 Aug 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-16
    Guest-16 Guest
    FOUR HUNDRED AND FOURTY SIX PERCENT :eeek:
    And Tmpeg was one of the things Intel was poster childing as having SSE4.1 support :lol: back last November.
  3. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    YAY :D I hope to see more CUDA support in more apps!
  4. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    I am. :D Specially if CUDA would allow me to NOT having to wait overnight for an Adobe Premiere project to encode to a Video file...
    I can't wait to see how Adobe is going to implement CUDA on their programs (I do hope they do it on Premiere Elements).
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Come on AMD. I brought this card because it's bloody awesome, now I want some more uses for it.
  6. Jojii
    Jojii hardware freak
    12 Dec 2007
    um space heater?
  7. Cinnander
    Cinnander What's a Dremel?
    19 Apr 2007
    ahahah! You, sir, win the internet. For today, at least
  8. WildTangent
    WildTangent What's a Dremel?
    10 Oct 2006
    AMD may be ahead as far as hardware goes for now, but stuff like this is what's going to keep Nvidia on top, in my mind anyway. AMD is lagging far behind in the GPGPU segment at the moment.
  9. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Careful. The entire purpose of TMPGenc is to be really really damned good.
    I can make it 446 percent faster by making it really, really bad.
    Need some comparative SNR figures for what must be an entirely new encoder.
  10. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Not necessarily - it could be the same encoding algorithm using new code that is optimised for the GPU, so the result would be mathematically identical and hence indistinguishable from CPU encoded video.
  11. kenco_uk
    28 Nov 2003
    Just imagine, if CUDA was based on assembly language rather than C, the speed advantage would be 1337%.
  12. KayDat
    KayDat What's a Dremel?
    20 Nov 2006
    Or perhaps OVER 9000!!!
    Or not.
  13. wyx087
    15 Aug 2007
    the BadaBoom test on Anandtech didn't show very large improvement in encoding speed from q6600 to 8800GT (or was it 9800GTX, i remember it's a G92 chip)
    so IMHO it'd be best to leave Geforce to Fold while use CPU to encode.
  14. NeedForSpeed
    NeedForSpeed What's a Dremel?
    23 Dec 2008
    WARNING: TMPGEnc doesn't use CUDA for ENCODING but just for FILTERING.
    I've downloaded the trial version and used it to transcode an mpg video to divx: progress window shows CPU and GPU usage and while just trascoding it was 100% and 0%. So CUDA will speedup as much as nothing transcoding with TMPGEnc. :(
    Otherwise if you apply some sort of filtering to the video you are processing (for example noise reduction or contrast change) then GPU load goes up.
    So if you think this product will speedup your video conversions you are on the wrong road.
Tags: Add Tags
