News Nvidia's Lightspeed Studios is bringing RTX to classic games
Discussion in 'Article Discussion' started by bit-tech, 14 Oct 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. jb0
    jb0 Minimodder
    8 Apr 2012
    "actively recruiting staff to bring RTX technology to 'a title that you know and love.'"
    But I'm not sure that Terminal Velocity really NEEDS raytracing.
  3. RedFlames
    23 Apr 2009
    Can you raytrace pong?
    MLyons likes this.
  4. Omnislip
    Omnislip Minimodder
    31 May 2011
    Presumably this is because only the oldest games can actually run with ray tracing at >=60Hz at a reasonable resolution?
  5. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    Psyconauts
    Spraduke likes this.
  6. Spraduke
    Spraduke Lurker
    23 Sep 2009
    You know what, if they added it to Psyconauts I would jump on the hype train and get one! (also possibly HL1 which is a fair chance that's what they mean if valve play ball)
  7. jb0
    jb0 Minimodder
    8 Apr 2012
    Maybe they'll do Doom*
    *As per original system requirements, requires 70Hz monitor. Time to go GSync, peasants!
  8. Gareth Halfacree
    4 Dec 2007
    ...Doom never specified a particular refresh rate, and from memory was unable to make use of any of the 70Hz 'high'-refresh-rate VGA modes (at least, in the original MS-DOS release) . To quote the documentation:
    EDIT:
    Wait, I'm second-guessing myself, now. Let's see, Doom used a tweaked 320x200 Int 13h VGA mode stretched to a 4:3 resolution... which doesn't specify a refresh rate. I guess it *could* have been running at 70Hz - someone needs to fetch me a CRT with OSD, 486 with VGA output, and a floppy drive...
    EDIT EDIT:
    Turns out my memory is faulty: most MS-DOS games of that era, including Doom, ran at Int 13h (320x200) 70Hz, not 60Hz. Mea culpa!
  9. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Raytrace the ships and "skybox" for Homeworld
    Update Freelancer with raytracing graphics
    I'll be the first in line to buy a RTX graphics card.
  10. Vault-Tec
    30 Aug 2015
    HL2 would crack my resolve. Mostly because when it released I used to spend ages just standing there taking in the scenery. I'd like to do that again :)
  11. jb0
    jb0 Minimodder
    8 Apr 2012
    Credit where due, I only knew because I saw something turn up where someone was complaining that one of the recent console ports of Doom sucked because it ran at 30FPS instead of 35 FPS and apparently this affects the "physics" significantly. (And it almost immediately turned into everyone trying to figure out why it would run at a weird number like 35 FPS in the first place, since that doesn't go into 60 at all.)
    But I did in fact boot a K6-2, start Doom, and check the monitor's status display to verify it was 70Hz.
      File size:
      298.8 KB
      248
    Gareth Halfacree likes this.
  12. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    I vote for Crysis, that way “But does it run Crysis?” Can have a whole new lease of life :)
    jb0 and Spraduke like this.
Tags: Add Tags
