Graphics NVLDDMKM – display driver stopped responding and recovered- Crysis…death of my 8800GT
Discussion in 'Hardware' started by bhanja_trinanjan, 1 Aug 2009.
Did you RMA 8/9 series DX10 Nvidia cards?
  1. Yes
    12.5%
  2. No
    87.5%
  1. bhanja_trinanjan
    bhanja_trinanjan What's a Dremel?
    15 Apr 2008
    Hi,
    So that’s what I have been getting since last evening. No texture/display corruption, just freeze and NVLDDMKM. Had these errors in the past and I fixed them by running the 8800 fan @ 100%. That fix is no longer working. Temperatures (including GPU) are fine and voltages solid.
    Time for RMA…:-how many of you guys have had failures with Nvidia 8 series parts? :wallbash:
  2. atanum141
    22 Jul 2004
    what about changing the driver? i had this issue but it was only resolved by doing a fresh install of Vista.
  3. bhanja_trinanjan
    15 Apr 2008
    Latest drivers, bro 190 release WHQL... nothing overclocked.
  4. GoodBytes
    20 Jan 2007
    Did you try the 186 series drivers? maybe it's a bug in the 190 drivers.
  5. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    I used to get that in Crysis with my 8800GT, but seemed fine inbetween and had no longlasting effects. Latest drivers aren't always the best, they can fix old problems bring up new ones :sigh: maybe have a fiddle with different drivers and see if it helps?
  6. Paradigm Shifter
    10 May 2006
    I had an 8800GTX 'die' on me two days after I installed it. I guess it got knocked around in transport or something and had a bad contact on something, as for the first day it was OK, the next day it got a lot of work and started artifacting all over the place. But I had terrible luck with the 8 series cards as I had two 8800GT's DOA - plug 'em in and nothing (except BIOS beeps for VGA failure...)
    The third one worked fine, though, and is still going like a trooper. :)
