NZXT 240mm Kraken X52 installation question
Discussion in 'Watercooling' started by kuroidoragon, 17 Dec 2018.
  1. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    I have a question I have the following Motherboard
    Asus - TUF Z370 Pro Gaming ATX LGA1151 Motherboard
    I would like to know if the NZXT 240mm Kraken X52 RGB All In One CPU Water Cooler Intel/AMD
    is compatible with my Motherboard & if there is any issues with installing it to my motherboard if anyone knows or can advise please ?
  2. TheMadDutchDude
    23 Aug 2013
    No issues at all. It’ll be just fine.
    kuroidoragon likes this.
  3. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    does it plug into the Motherboard header or usb my dad has the 280 mm version in his pc & was saying something along those lines finding the wiring difficult
  4. TheMadDutchDude
    23 Aug 2013
    It will more than likely plug into the header near the bottom of the board. That would be my guess having dealt with a few AIOs in the past. :)
  5. Sentinel-R1
    Sentinel-R1 Morse Monkey
    13 Oct 2010
    There's nothing difficult about it mate. It has a SATA power connector for the pump and LEDs and then you connect the tacho wire to the CPU fan header. The two supplied fans connect to the pump and are controlled by the CAM software. That's as simple as it gets.
  6. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    What is a Tacho Wire? I am sure it is short for something but I don't know what
  7. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    Tacho is tachometer, measures how fast the fans and/or pump are spinning.
