News NZXT releases water cooling-ready H440
Discussion in 'Article Discussion' started by Meanmotion, 14 Jan 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Parge
    16 Jul 2010
    I don't massively like the exterior but the interior is GREAT! Gooooodbye useless 5.25" bays!
    (Bay res.... nah - use a tower people!)
  3. Maki role
    Maki role Dale you're on a roll... Staff
    9 Jan 2012
    NZXT really have put on their thinking caps of late. The interior seems quite Enthoo Primo-esque, which certainly no bad thing. I just wish that they hadn't extended the damn window past the PSU shroud, there's clearly nothing down there other than their name.
    The shroud itself seems designed well, great idea for a place to pop SSDs so that they're easy to access, on show (after all SSDs tend to look pretty awesome) and neat.
    If the black and red combo looks as good in real life as in that render, then I'll be very impressed. Usually red when placed on a case itself looks a bit odd and out of place, that seems to fit quite nicely.
  4. Dogbert666
    Dogbert666 *Fewer Staff Administrator
    17 Jan 2010
    Hooray for no optical drive bay!
  5. saxovtsmike
    saxovtsmike Member
    12 Aug 2008
    No 5.25 bay, no Aquaero :-(
    Hopefully the Radiator mounts in the Top ar off Center or the case is big enought to fit at least a propper 45mm 360 rad in the top + 25mm Fans
    Same for the Front, Lets pray on them not having failed and a Front 360 with fans will interfere with a top 360..
    Like the SSD Mount and the hidden psu...
  6. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Looks big. Room for EATX?
  7. Nexxo
    23 Oct 2001
    Dude, are you a modder or a mouse? You're a MODDER, of course! You hay no feart of the Aquaero. You LAUGH in the face if having no 5.25" bay! YOU are MASTER of this case. You OWN it. You DOMINATE it. You are not intimidated by the lack of 5.25" bays; you EMBRACE the CHALLENGE! YOU CONTROL YOUR OWN DESTINY. YOU CARVE YOUR OWN PATH. YOU. ARE. A. MODDER. THIS. IS. BIT-TECH!!!
    Er. Too much? :worried:
  8. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    No not far enough. You need to march round his house and kick him squar in the nuts.
  9. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    OMFG, this made me spit out my soda... Strong willed is this young padawan.
    This case screams to be modded. I for one am willing to mod one with some epic designs.
  10. JCBeastie
    JCBeastie New Member
    10 Nov 2005
    It actually doesn't have a front door. The front panel looks very door like but just exists to be a smooth surface in front of the fans, NZXT call it doorless and ODD-less. :p
    That being said it looks gorgeous. Real winner here, well priced to boot!
  11. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    I was just about to buy a 750d to replace my 500r - but this has got my attention...
    Looks like I will be moving my blu-ray drive to my HTPC...
  12. iggy
    iggy Active Member
    24 Jun 2002
    far too much. THIS. IS. DENNIS. :(
    i like this case though, its almost as if someone at nzxt was fed up waiting for antec to bring out another p180 without all the stupid sticky out bits. if only it was a weee bit taller, but i suppose you could remove the fan mounts from the front plate and shuffle everything down a little.
Tags: Add Tags
