Hardware NZXT S340 Review
Discussion in 'Article Discussion' started by Dogbert666, 18 Mar 2015.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Considering the amount of free space you gain from shaving the drive bays, I'm kind of disappointed that this doesn't support E-ATX out of the box.
  3. rollo
    rollo Modder
    16 May 2008
    Touch expensive for the targeted budget builder. £60 is more mid range surely than budget price.
  4. Dogbert666
    17 Jan 2010
    I think it straddles the line tbh. It's at the very limit, but you may be right. It was actually £55 at one point, shame it's gone up, but stiill worth it I think.
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I have this case and I would absolutely recommend it to anyone looking for an ATX case who doesn't require mounting spaces for a lot of 3.5" hard drives. It's an excellent budget conscious case, though can easily hold it's own with cases that cost 2x as much or more.
  6. Parge
    16 Jul 2010
    No optical drive bay! HURRAY!!!!!
  7. Pirra
    Pirra What's a Dremel?
    7 Nov 2009
    I have this Case, actually i'm working on a Modding project on it. I definitly recommend it. It a great case y in think that is the best bang for your buck. Great features, packed in a minimalistic desing. Lots of free space to use as a canvas for a great Modding ideas.
  8. InSanCen
    InSanCen Buckling Spring for life
    30 Mar 2005
    I want one, but I need 4x 3.5 mounts. Is there anything out there, at this kind of price, with this kind of "minimalist" front end that can do that? Full ATX needed (Sabretooth 990FX board).
  9. IvanIvanovich
    31 Aug 2008
    NZXT H440, though it's more expensive by a lot and isn't as plain looking. But it is kind of similar looking and has 6x 3.5 mounts available. I most likely would have ended up with one instead if the S340 didn't exist.
  10. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    looks amazing, especially considering the price.
Tags: Add Tags
