Hardware NZXT Switch 810 Review
Discussion in 'Article Discussion' started by brumgrunt, 7 Mar 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. David
    7 Apr 2009
    Again, with the radiators! :D
    I really am enjoying some of the changes at bit-tech. :thumb:
    As far as the case goes, I was thinking the same thing. Why bother, when you can have the Elysium?
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    I have the Elysium and will be sticking with it for a while yet.
    I currently have a 360mm 60m thick rad in the roof with, 3 fans on the inside of the case and 3 on the outside.
    I could fit a 360mm in the front of the case and also a 240mm in the bottom with a bit of work, the only thing that I find interesting about this NZXT is the front pannel that can be removed so easy.
    It certaintly is a good case but it's something that I won't be getting, although I may tell my brother in law to grab one of these for his pc, or I may get one for my dads pc.
    Saw a hour long video review for this case on another site, that showed a few issues with this case, like the plastic part in the optical bay at the top which blocks part of the fan on the last fan if you run push pull.
    Good review though.
  4. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    I do like NZXT case just got a Source 210 for a NAS, however I really hate how they have supplied screws that fit the holes if they were not filled with bloody powder coat, fitting the mobo mounts should not be a massive task, though I did like the little wrench/nut they supplied to fit them
    Kimbie
  5. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Ill stick with my much smaller NZXT Vulcan ;) Full CPU and dual GPU water cooling in a small desk top friendly form.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Bottom of the first page, you guys say 'This still makes it much more desk friendly than the huge Xigmatek Utgard (663mm high) or the SilverStone TJ11 (642mm high). ' when I'm sure you're referring to the Elysium...
  7. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    I love how it looks, but i found myself saying "damn, is that all plastic?". Apparently it is. Too bad though, it looks real nice. I fell into the plastic trap once before, and never again will i go down that road.
  8. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    yeah im sure he is, the utgard is 515mm high
    its the Elysium thats 663mm
  9. Jipa
    5 Feb 2004
    Because IMO the Switch looks much, MUCH better than the Elysium.
    I actually had one of these around, and while yes, it's all plastic, it didn't really bother me. Ofcourse you do notice it and can make the panels rattle if you try, but in normal use? I don't see the problem.
    Thanks for the review! And special kudos for the photos, I've been struggling to get good shots of another gloss white case and it's an absolute cluster**** without a proper studio...
  10. tigertop1
    tigertop1 What's a Dremel?
    23 Apr 2009
    The reviewer ought to be pleased that NZXT has not included a fan controller. Issues with the supplied controller on the Phantom and new 410 cases have been the source of many frustrated comments on the NZXT website forum. NZXT is an innovative designer but attention to detail is often lacking in the production runs and Customer Service response is non existent.
    If you are prepared to do a lot of DIY on a new NZXT case it can be rewarding but a little more thought in the design process could turn a good case into an excellent one
  11. TheDarkSide
    TheDarkSide What's a Dremel?
    22 Feb 2011
    Nice review!
    Shame the case doesn't look as original as the phantom.
Tags: Add Tags
