Modding NZXT Tempest EVO Side Fan Removal
Discussion in 'Modding' started by Strudul, 4 Aug 2010.
  1. Strudul
    Strudul ~
    31 May 2010
    I hae an NZXT Tempest EVO, and I want to remove the side fan (the one in the window), and I can not work out how to get it off. There does not seem to be any screws and I dont want to break things.
    Does anybody know how to get it off?
    Thanks
  2. Strudul
    Strudul ~
    31 May 2010
    anyone?
  3. J05H11E
    J05H11E Fujitsu Technical Analyst
    5 Aug 2010
    Brute force :)
    I haven't got this case but isn't it screw mounted?
  4. jonni3
    jonni3 What's a Dremel?
    17 Mar 2010
    It looks like it uses the same fitting system as my M59 on the window fan, they are four push-in type pins.
    All you have to do is push the pins from the inside then pull the pins out & the fan will then com away from the window.
    pin closed
    pin open
    pin removed
    Hope this helped...
  5. Strudul
    Strudul ~
    31 May 2010
    yeah it looks the same. Ill try it.
    What did you use to push the pins out?
  6. jonni3
    17 Mar 2010
    Just a finger, there not really that hard ......
  7. Strudul
    Strudul ~
    31 May 2010
    Got it :D thanks
