O/C AMD AthlonXP 2400+
Discussion in 'Hardware' started by Griffo, 12 Feb 2004.
  1. Griffo
    Griffo What's a Dremel?
    8 Jan 2004
    Anyone had a go at O/C an athlon 2400? From what I hear, with the unlocked versions you can get great results. Just wondering if anyone has tried, as I may have a go with my new chip when she arrives! :D
  2. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    the overclocking ability depends on so many things im just going to say "depends ... " You have to look at your system as a sum of parts, not a group of single items.
    Best thing to do is have a go and see how far you get. Most importantly, especially if your new to it, take it slowley. Only alter one setting in the BIOS at a time to see how it affects the system. You should back up any important data before you start also.
  3. SpeedFreak
    SpeedFreak What's a Dremel?
    28 Mar 2003
    never o/ced a 2400+ b4 but have messed with some other AMD offerings, just slowly up FSB and up voltage and you should be able to get somewhere close to 200 FSB.
    i got a 1ghz overclock on my 1800+ (11.5x133 to 11.5x222) :D
  4. Darv
    Darv Bling!!
    12 Aug 2002
    Have a look in the Super Pi thread at the top and you will see quite a few people with XP2400's overclocked quite high.
    I managed to get mine to 207*10.5 (I think) but it my RAM and mobo are holding me back, that and I'm still waiting for my watercooling :naughty:
  5. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    My 2400+ runs fine at 2.1ghz at 400fsb at about 1.7v but ive not really tried to go any further :)
  6. Griffo
    8 Jan 2004
    Never done any O/C before, so might take your advise there and take it one step at a time. Try not to burn her out on the first attempt eh? lol :D :blush:
  7. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    My 2400+ did 12x200 no problems, think that was about its limit on air though. Lemme check that you are talking about the normal Tbred 2400+ and not a mobile Barton? They're amazing, hand-picked unlocked Barton cores that will run at 1.45V and clock wonderfully :D
  8. Griffo
    8 Jan 2004
    Mine is the T'bred version for my desktop pc. How will I know if the CPU has been locked or not?
  9. Kameleon
    29 Apr 2003
    There'll be a code written on a sticker on the chip, reading something like this:
    AXDA2400DKV3C 4152289242418
    AIUHB0301MPM
    That's mine, if the numbers I've emboldened are 0339 or earlier then it'll be unlocked, if it's 0340 or later it's locked.
  10. Tim S
    Tim S OG
    8 Nov 2001
    2300Mhz would be a nice round number to aim for, with good ram and a good processor, you could hit 2400-2500Mhz on air.
  11. olv
    olv he's so bright
    23 Sep 2002
    Will those that know their 2400+ stepping post it along with their max overclock. I managed to look at mine yesterday, but never properly overclocked it. had it post at 2495mhz at 166fsb about a year ago.
    AXDA2400DKV3C 9182556270493
    AIUCB0242WPCW
    not an AIUHB unfortunately, but could be worse.
  12. Kameleon
    29 Apr 2003
    Well I've been playing with my above chip in my old 8RDA+, and with 2.2V through it (BIOS max) it'll POST at 207x13, 2691MHz. Totally Prime stable at 2400MHz, I'm about to do some more tests to see if it'll go any higher than that. This is all with a Vantec Aeroflow HSF too, so there'd be a lot more in her if I got a better heatsink/water going. Bwaha!
  13. Mr T
    14 Nov 2001
    My 2400 is the following stepping...
    AXDA2400DKV3C
    9440798270211
    AIUHB 0247XPBW
    Should that be anygood at overclocking? I havent really taken it above 1.7v
  14. Kameleon
    29 Apr 2003
    Should be, yeah. Pump it up to 1.9-2V and see :D
  15. Mr T
    14 Nov 2001
    Not with this current heatsink its in the high 40's at idle :(
  16. Kameleon
    29 Apr 2003
    It's HAMMER TIME!!!
    :worried:
    Er, upgrade time, perhaps I meant...
  17. Mr T
    14 Nov 2001
    What temps do u get with out zalman? And is it nice and quiet?
  18. Kameleon
    29 Apr 2003
    At 1.95V, I'm idling at about 39° and full load temps are around 45° - and I can't hear it at all above my other fans, even when they're all at 7V and it's at 12 (as it is all the time, there's no need to turn it down). That reminds me - have to change my sig to reflect the new board :D If you're interested, read this thread about them (Geez, I know the threadid now, how very sad :p) but you will get better temps with a Thermalright SP97 and a Tornado :D
  19. Mr T
    14 Nov 2001
    Does it fit the nf7-s fine? i wonder if the performance difference between that and the "Zalman CNPS7000A-AlCu" is much :)
  20. Kameleon
    29 Apr 2003
    You're too fast :p, read my edit of the last post and in particular the thread I linked to. The AlCu is very very similar to the Cu in every way except weight, you're looking at about 1°C difference.
