o/s
Discussion in 'Software' started by llah66, 26 Feb 2008.
  1. llah66
    llah66 What's a Dremel?
    23 Feb 2008
    getting new system on tuesday from cyberpower systems but need advice now on which o/s to get do i do for 32bit or 64bit , my system will be nforce750i-sli M/B.ocz 4gb RAM.400gb sata-ii 3.0gb/s 7200rpm H/DRIVE. xfx geforce8800 gtx extreme gamer 760mb G/CARD.800watt tagen PSU.extreme qx9650 3.00ghz CPU.
    so any advice would be apprecieted.
    thanxs llah66:D
  2. Brett89
    Brett89 Minimodder
    15 Dec 2005
    64 bit, it will allow for the 4gb of ram to be addressed as such.
  3. llah66
    23 Feb 2008
    is there any probelms though with some hardware and running games on a 64 bit
  4. GoodBytes
    20 Jan 2007
    New hardware will not/should not have any problem with 64-bit Windows Vista.
    Just make sure your printer and other peripherals has 64-bit drivers, or compatible drivers, as you cannot install 32-bit drivers inside 64-bit OS (of course).
    If your printer or other peripherals have "WinXP Pro 64-bit" drivers, then it should not have any issue under Vista 64-bit, but contact the company to make sure.
  5. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    os/2 warp.
  6. Brett89
    Brett89 Minimodder
    15 Dec 2005
    the 64 bit issues with hardware is from XP 64 bit, Vista is fine.
  7. GoodBytes
    20 Jan 2007
    Right, what I wanted to say is that if you decided to get an old hardware like... an Nforce 2 for some reason, you won't find any official Vista 64-bit drivers.
  8. Brett89
    Brett89 Minimodder
    15 Dec 2005
    Well said Goodbytes.
