Core 2 Duo series are the first CPU with LGA775 socket; after launching C2D for few months, Intel released the hi-end LGA775 solutions “Core 2 Quad”. Currently, Core 2 Quad is still expensive. It costs more than USD $170 even you buy the cheapest one. However, after price competition between AMD & Intel in mainstream market, the price of C2D is more acceptable. For example, there are E8X00 (FSB 333MHz/ 6MB L2), E7X00 (FSB 266MHz/ 3MB L2), E5X00 (FSB 200MHz/ 2MB L2) and E6300 (266MHz/ 2MB L2) for mainstream & extreme performance. Or, you can also choose entry level solutions like E1X00 (FSB 200MHz/ 512K L2). All above CPU are based on C2D micro-architecture, there are only different in L2 cache & frequency. One of the leading roles today: Intel Core 2 Duo E7500/ 2.93GHz/ FSB 266MHz/ 3MB L2 cache. E7500 CPU and cooler by Intel There is no cooper basement in this cooler; you can see it only in Quad core processors. E7500 P45 is the latest chipset which supports LGA775 CPU, the potential of overclocking is very good. DFI usually adopts ”Red” PCB into Blood-Iron series. There is a sticker near north bridge to remind “Warranty avoid if you remove the cooler” (as you see, there is no metal cover to protect Intel P45 chip). In my experience, if you change the cooler without damage the chipset, DFI will cover the warranty. So, please be careful when changing north bridge cooler. P45 motherboard is the best OC platform for LGA775 CPU. To get higher performance, you have to fine tune some options for E7500 (R0 stepping). BIOS setting for 500 x 8 => 4000MHz CPU clock0 Skew: choose 100 or 200ps GTL is key option for R0 stepping when OC FSB The suggested number is 0.63/ 0.67/ 0.58X If you want higher DRAM frequency, you can try 3/3/1 as the picture below. If the DRAM quality is not good enough, you can ry 4/4/1. Testing platform CPU: Intel Core 2 Duo E7500 MB: DFI LANParty P45-Elite DRAM: CORSAIR Dominator TWIN2X4096-8500C5D VGA: MSI R4890 CYCLONE DDR5 1GB HD: CORSAIR CMFSSD-64GB2D (RAID 0) POWER: CORSAIR 400W Power Supply Cooler: Thermaltake BigTyp VP Default stting CPU 266 X 11=> 2926Mhz DDR2 1064 CL5 5-5-15 2T Hyper 2 X PI 32M=> 18m 44.029s CPUMARK 99=> 442
CrystalMark 2004R3 CINEBENCH R10 1 CPU=> 3549 x CPU=> 6825 PCMark Vantage=> 7969 3DMARK Vantage CPU SCORE=> 5843 The default frequency of E7500 is 2.93GHz; it’s powerful enough for most tasks. In addition, 3MB L2 is also large enough. Testing under overclocking CPU 500 X 8=> 4000Mhz DDR2 1000 CL5 5-5-15 2T Hyper 2 X PI 32M=> 14m 13.228s CPUMARK 99=> 577 CrystalMark 2004R3 CINEBENCH R10 1 CPU=> 4807 x CPU=> 9355 PCMark Vantage=> 9769 3DMARK Vantage CPU SCORE=> 7883 Core voltage under Hyper PI 32M is 1.248V, but t drop to 1.232V in full loading. It means E7500 needs only 1.232V when OC to 4GHz, such as E8X00 series. Under two different Vantage benchmark, it also needs 1.232V for 4GHZ. 3D test with MSI R4890 CYCLONE.
StreetFighter IV Benchmark 1920 X 1200=> 18500 Biohazard5 Benchmark With 4890 and overclocked E7500, StreetFighter IV & Biohazard work smoothly under this platform. To challenge the OC limitation under air cooling. CPU 411.7 X 11=> 4529MHz Hyper 2 X PI 32M=> 13.931s CPUMARK 99=> 654 To compare with 4GHz 1.232V, you can get higher result to 43.GHz by over voltage a little bit more. Between E8X00 & E5X00 series, the E7500 product position is peculiar. Someone think E7500 is just E6XXX with larger L2 cache, but I don’t agree. According to the frequency and performance, E7500 should be hi-end product such as E8X00 series. If you need to compress or en/decode audio & video files, E7500 with 3MB L2 cache is better than E5X/6X00 with 2MB cache only. E7500 is a little bit more expensive than E6X00, but not so expensive as E8X00, I think it’s a compromise choice
Thanks; did you test long term stability with the overclock at 4GHZ or 3,6 GHz? Bit-Tech had an E7400 in their monthly guide, with the promise of doing an overclock guide (since the colleagues at Custom PC love it....) but we have never seen that guide.
Nice, love the little dog to show scale, maybe somethimg more tech orientated next time though , like an XBox 360/ mouse
