Cooling OCPC Neptune Mounting
Discussion in 'Hardware' started by George, 28 Jul 2002.
  1. George
    George Bah
    14 May 2002
    hey,
    can i just ask, how is the OCPC Neptune (AMD) block mounted onto the socket?
    thanks,
    .icecube
  2. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    No m8 its mounted by the four holes round the socket,so you will need to take of your mo-bo to fit it ,also what im going to do is cut a square hole out of the back of my case right above where the cpu socket is so i can take it of if needed+plus this will save time.
  3. George
    George Bah
    14 May 2002
    ok, thanks mate.
    .icecube
  4. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
