Scratch Build – In Progress octTower - Completed - Final photos round II
Discussion in 'Project Logs' started by craig - toyoracer, 25 Aug 2011.
  1. JY_OC_HX
    JY_OC_HX Minimodder
    2 Feb 2011
    WOW The concept and vision you have is immense!! Definately following this!
  2. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Soo...shinnyy...:eeek:
    Looking niiiiice. Good designwork and fabrication, keep it up! :dremel:
  3. Guest-56605
    Guest-56605 Guest
    I'm liking that custom shroud chamber for the CPU cooler, It will be interesting to see what temps it yields :thumb:
  4. sebpruiz
    sebpruiz What's a Dremel?
    9 Jul 2011
    Wow this is really good!!! subbed.
  5. amppatel
    amppatel What's a Dremel?
    25 Aug 2011
    WOW - this is really good work, best I've seen, it looks like a cofee machine!! But it really does look amazing, you should start selling custom cases with your skills!
  6. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Thanks man :)
    Thank you :D
    Thanks man try to get everything with a clean smooth look :)
    Thank you yes that shiny made for a lot of work, it shows everything :hehe:
    Thanks man, my hope is to not have fan mounted to cooler, cause I like the look of it :D
    Thank you, glad you are all liking it. This modding thing is a lot of fun :D
  7. craig - toyoracer
    1 Mar 2011
    After a very unexpected delay, life over play-time, I am back to finish my build.
    So I need to make the 8 pin cable. Starting with new wires crimped then sleeve them into the connector and on goes the first epoxy layer.
    build it up to desired shape.
    stretch the sleeve and repeat on the other connector.
    then file to shape and add more epoxy where needed.
    then they get painted.
    Have a couple more to make, but I will be back. :)
  8. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    heres you put the right wires in the right holes :D:D:D:D:D
    they look really nice by the way and its cool to see new ways of cabling!
  9. craig - toyoracer
    1 Mar 2011
    Yes checked twice with multi-meter before. :)
    Thanks, thought I would try it out, I am pleased with the results. A lot of time to make, but that is the only way sometimes to get what you want. :)
    Waynio likes this.
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    I meant to pop over to your log as soon as you shown me the excellent looking spotlights picture a few months ago, then meant to again the other day when I noticed the link in your sig, but now finally got over here to comment & subscribe :D.
    Awesome looking project made with great skills, cool method for making angled power connectors too :).
    5 star +rep + looking forward to more :).
  11. bulldogjeff
    2 Mar 2010
    Oh yeah, those cables look wicked, nice work dude.
  12. Cheapskate
    13 May 2007
    Everything looks great so far...-'cept for the first pic in your last update. I could have lived without that one. It looks too much like you sneezed.
  13. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    We need updates! :p Jk buddy, fantastic job and these cables came out magnificent!!! Mod on buddy I eagerly wait for more!! :)
  14. Gambo
    Gambo What's a Dremel?
    26 Oct 2011
    Craig.. a pleasure to see you here.
    you've done a fantastic job on those connectors. :D
    keep'em coming!
  15. peteski
    peteski long live the pc
    8 Jun 2011
    really smart build mate your skills are truly amazing :rock: :rock: :rock:
    + rep
  16. craig - toyoracer
    1 Mar 2011
    Thank you Wayne. I am glad to have you here.
    Started on the 24 pin, which turned out well and has taken over the rest that needed a change in direction. :lol:
    Thanks for the star & rep, and more is now.
    Thanks bulldog. :D
    :) maybe where we start is not always pretty. Thanks cheaps. :)
    More is here now. :D Glad your are enjoying.
    Thank you my friend, glad to see you here. :clap:
    Thank you very much. :D
    Update :D
    Front I/O cables have a problem reaching motherboard, because of so little space between tray and PSU.
    So made a couple of holes so the cables will be above the PSU. Made 90˚ cable plugs, to give a neat and tidy look.
    Now need to finish the other side to connector.
    I will be back soon with them finished. :D
  17. AnG3L
    19 Mar 2009
    Another neat idea!!! Mod on brother! :)
  18. Attila
    Attila still thinking....
    22 Feb 2008
    Those home made right angle thingies look great. :thumb: I can see some of those in my future. :D
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Yeah he gave birth to an awesome idea there which many will emulate including me :D.
  20. craig - toyoracer
    1 Mar 2011
    Thanks bro finally have them done.:)
    Thank you happy to inspire. :) I should have made a mold it would have been quicker. :hehe:
    Thanks man, glad you like. Share the experience. :)
    Well have them done. After making a mistake in the hole placement. Was a bit to high, so filed downward then needed to file the USB elbow. The cables were stacked and I needed them side by side, then remade elbow.
    So here they are connected up. :)
    The 8 pin connected. :) Man the camera shows every little thing :wallbash: no it's not a real good mirror finish, just a shiny one. :hehe:
    Mounted up the SSD only using 1 right now so the other holes are plugged.
    Well I have a few things left to do, so back soon. :)
