Build Advice OCZ Agility 3 causing Win7 to freeze?
Discussion in 'Hardware' started by Necrow, 12 Oct 2011.
  1. Necrow
    Necrow Minimodder
    24 Feb 2009
    Last weekend I installed a new mobo, memory and CPU along with a new SSD the OCZ Agility 3. It is my first SSD so I was keen to follow all advice for TRIM, Defrag, Windows Search etc..AHCI was also enabled in the BIOS. I used this guide: http://www.computing.net/howtos/show/solid-state-drive-ssd-tweaks-for-windows-7/552.html
    All ran fine for 1 day but now it seems to cause Windows to freeze. My system specs are:
    Mobo - MSI P67A-GD55 (B3) - Socket 1155- ATX Intel P67
    CPU - Core i5 2500K / 3.3 GHz - LGA1155
    Memory - Corsair Vengeance - Memory 1600MHz - 8GB
    SSD - OCZ Agility 3 SSD 60GB 2.5" SATA-600 Read
    PSU - OCZ 600W
    OS - Windows 7 Ultimate 64 Bit (Fresh install)
    For storage I also have 3 1 TB Samsung F1's.
    Cooling XSPC Delta with 2 x 120mm Rad and Xigmatech fans.
    Temps are good and overclock is with OC Genie (until I can stop freezing) It actually freezes even with no OC at all. I see that there some support sections on the OCZ Forum but I don't have access even after registering.
    http://www.ocztechnologyforum.com/f...d-boards-Vtx3-Agility3-Solid3-BSOD-setup-info
    Can anyone help? This does seem common but I can't find how anyone is resolving it?
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    thehippoz likes this.
  3. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Stupid question but have you updated your bios recently? I updated mine after installing my SSD and it reset my settings in the bios from achi to ide. Could be worth a check, caused me alot of headaches when I got the ssd
  4. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    When you say you have tried with no overclock, did use the reset to default option in your motherboard bios? If not try using that.
    do you get any blue screen errors or just a hard lock? Does windows event logger give you any information?
    I had a similar problem which actually turned out to be the psu, im guessing that this is not new and was carried over from your last build? If so I think it would be worth testing it with another
  5. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    did you install the windows ahci drivers in windows before activating it in bios? did you do the firmware update on the SSD before installing windows?
  6. Necrow
    Necrow Minimodder
    24 Feb 2009
  7. Necrow
    Necrow Minimodder
    24 Feb 2009
    No I'm fairly certain that I checked the BIOS several times and it is still set to ACHI. It was IDE first when I installed Win7 but I changed it soon as I read that guide above.
  8. Necrow
    Necrow Minimodder
    24 Feb 2009
    On the MSI there is a nice little OC Genie button that allows for 1 second overclock. If I use this it runs at around 4.5 and without it it runs at stock 3.3. I haven't played with manual overclock yet as I'm waiting until I have SSD stable
  9. Necrow
    Necrow Minimodder
    24 Feb 2009
    Actually no I am stupid and installed Win 7 before I realised that the latest SSD is shipping with an old firmware. I haven't updated it yet, I will try this tonight but I read that it will cause problems as it is where the OS resides.
  10. Necrow
    Necrow Minimodder
    24 Feb 2009
    To all posters above, thanks ever so much, this is why this community is so good for advice and help :)
