Hardware OCZ DDR2 memory group test
Discussion in 'Article Discussion' started by Tim S, 16 Jul 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    not impressed with the reaper thats good to know i was thinking of getting them over the standard 8500+ SLI editions but probably wont now
    would have been good to see a direct comparison between the two tho to compare the cooling technologies
  3. Lian Li Lover
    Lian Li Lover New Member
    17 Nov 2006
    You complained slightly that when not watercooling the flexXLC, there would be nasty insulating air inside the heatsinks. Surely that could be solved by putting some water in the heatsinks and sealing off the ends of the barbs? It wouldn't perform as well as if the 'sinks were solid metal, but the water should be much more conductive than air. Still a bit of a hassle though.
  4. Guest-16
    Guest-16 Guest
    sure, that's certainly a solution but one many might be wary of should it leak :)
  5. Lian Li Lover
    17 Nov 2006
    Just as likely to leak as normal water cooling.
    edit: actually, the water would expand as it got hotter and could put the seals under lots of pressure and is thus a bad idea unless you left some room for it to expand.
  6. Guest-16
    Guest-16 Guest
    That and unless you find bungs specifically made for it I meant, whereas normal watercooling should use good tubing and clamps.
  7. Lian Li Lover
    17 Nov 2006
    Something like this
  8. Tim S
    Tim S OG
    8 Nov 2001
    Blocking water in there would be dangerous IMO - it'll be like what happens when you run a watercooled system without the pump turned on... pressure builds up and things eventually burst.
  9. masteroffm
    masteroffm New Member
    16 Oct 2006
    this is what I imagine routing the tubes would be like on the flexXLC
    Tim S, do you have a larger version of your avatar, I am a bunny person and that picture is awesome.
  10. Tim S
    Tim S OG
    8 Nov 2001
  11. Nature
    Nature Member
    21 Nov 2005
    Flawess review in itself. But I'd like to see a really low end module tested with higher end group to see the actual diference in the benchmarks... no site does this. The benchmarks as they are now, are so scrunched together in the graphs, that it seems that you would buy the memory specific to your applications as some are stronger in some different games, encoding, audio tasks, etc, or just pick one which is cheap because there isn't much of a statistical difference across the board.
    Like this piece of shoddy.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820159010
    What happened to le Foums!?
  12. completemadness
    completemadness New Member
    11 May 2007
    but as all the barbs point up, when your trying to loop up your going to get in the way of the other set
    OCZ should supply a block to get water in 1 side and out the other with 1 barb :p (sadly i don't think mobos are standard so it wouldn't actually work, plug as OCZ have barbed it already its will be hard to do anyway
    As to the article, to me the first few graphs i looked at made no real sense, you had the memory all mixed up in different places, some at the top, some at the bottom, some in the middle, however the graph doesn't go fastest to slowest, so IMO it just seems to be a bit of a jumbled mess
    here's a picture showing what i mean
    as you can see, i have linked up the same modules, their all over the place, but the entire lot isn't ranked fastest to slowest, so i really don't understand how you ended up in this crazy ordering system
  13. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    They are ordered by speed 800mhz, 1066, 1142, 1151.....1250 :p
Tags: Add Tags
