Hardware OCZ ModXStream Pro 500W PSU
Discussion in 'Article Discussion' started by Tim S, 2 Apr 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. yanglu
    yanglu Hmm...
    20 Aug 2008
    I managed to bag the 600W version of that Modxstream Pro for £57 before Christmas. (Before the pound dropped and everything seemed to rocket up in price.) Its a fantastic piece of kit.
  3. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    i think i'd put a extra tenner down for the 500W Coolermaster Silent Pro Whisper Quiet Modular PSU
  4. Guest-16
    Guest-16 Guest
    Also very good! Well, at least the 700W is (I use it at home).
  5. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
  6. Guest-16
    Guest-16 Guest
    Fair enough, our 500W survived an extended full load test and it was still cool inside. Ive thrown it at a few systems and it works fine. I said in the review I can't vouch for the capacitor choice so whether that plays into the future is something to certainly question, but not something we can evaluate.
  7. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Regarding the the PSU's ability to cope with heat. It is ironic that given the budget price of this item, the typical cases this will go into, will probably have fewer fans and less sophisticated cooling, than the 700W model that originally failed Hardocp's high heat test.
    P.S. - Is the 'What Hardware Should I Buy' article out soon, always one of my favs.
  8. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    How about a review of the SilentXStream series(600w)? I think I remember reading that the two use different pcb's.
  9. Guest-16
    Guest-16 Guest
    I disagree - fans cost next to nothing, and look at the very popular Antec 300 which is under £50. The point is for 500W there's typically components being used with far less heat than 700W. A 500W is "low end" - 4830/4850 with dual core, but 700W and you're looking at basic multi-GPU or a GTX 260/280/4870/90 end of the market.
    Simply it did the job with everything we threw at it here.
  10. Turbotab
    4 Feb 2009
    Fair point, and I suppose people buying truly rubbish cases, would not even bother with a £60 PSU, but probably settle for a £25 no name.
  11. Guest-16
    Guest-16 Guest
    Ya-huh. 500W is an educated "low end", and yea I will freely admit we don't test the heat chamber effect unfortunately, but the fact it sits at 30-40C inside, which is one of the coolest PSUs we've seen, with 85-105C caps means the 500W *should* cope with a bit of system temp. :)
  12. Turbotab
    4 Feb 2009
    Time for Dennis Publishing to cough up for a sauna, important vital for heat and humudity testing:)
  13. Mech0z
    Mech0z What's a Dremel?
    27 Mar 2009
    Do OCZ use PC Power & Cooling units? Like Corsair uses Seasonic in their HXxxx units?
  14. Guest-16
    Guest-16 Guest
    Only in the EliteXStream products.
    The ModX, Fatal1ty and GameX are FSP or someone I think.
  15. anonemus
    anonemus What's a Dremel?
    19 May 2010
    I bought this PSU recently to power my E5200/5850 gaming rig. I searched for the OEM and found out that this ModX is made by Sirtec
Tags: Add Tags
