Hardware OCZ Octane 512GB Review
Discussion in 'Article Discussion' started by brumgrunt, 1 Feb 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. BrightCandle
    BrightCandle What's a Dremel?
    30 Apr 2009
    What a lemon of a firmware update. The big drop in performance suggests this might be a workaround for a hardware problem.
  3. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Bof. Mediocre performance and not hugely competitive prices. I'll pass.
  4. feathers
    feathers Minimodder
    11 Apr 2009
    I stopped reading as soon as I saw the price. Of course I should have stopped reading as soon as I saw the OCZ badge.
  5. Jasio
    Jasio Made in Canada
    27 Jun 2008
    This is a very expensive SSD- overpriced considering the much higher quality Crucial M4 512GB has been popping up once in awhile on sale at NCIX and NewEgg for $550- a significantly cheaper price for a faster drive.
    My personal opinion of OCZ may be rather colored, but I haven't experienced a single OCZ product that did not produce issues down the road (PSU's, SSD's, etc).
  6. kosch
    kosch Trango in the Mango
    12 Feb 2005
    When are you going to review some Mushkin SSD's?
  7. steve30x
    steve30x What's a Dremel?
    31 Aug 2008
    I remember when an SSD that size would be over €2,000. Assoon as a 512GB SSD is €512 I will buy one.
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    OCZ Petrol is really close at $600 for a 512GB.
  9. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    OCZ does not exactly have a prefect quality products (as mentioned above) and charging this much for SSD is an insult.
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    Another SSD from OCZ, another Firmware issue...
  11. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Great review Harry - Nice to see the before and after covered. Think I'll be skipping the current gen of SSD's and sticking with my Raid 0 M225's for a while yet....
  12. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    Raid and SSD seems pointless to me, as you lose Trim support under raid so the drive could end up slower then 1 ssd (1 SSD should enough as its faster then an hdd by 5x-200x depending on what your doing)
    is it normal for the C300 SSD to have high Write access times (1000ms+) as i have an M4 and it never really goes above 20ms
  13. Guest-16
    Guest-16 Guest
    TRIM support will change soon with the next set of drivers from Intel :)
    Baz - when you gonna get to the OCZ Petrols?
  14. leexgx
    28 Jun 2006
    trim support for none raid disks when BIOS is set to raid or ahci (current updated drivers have trim support )
    or support for trim for raid disks
  15. Kris
    Kris Lord Lolwut
    6 Jun 2008
    gsus, the price tag on bigger ssd-s is mindboggling. how can they expect to even sell them when the average person buys a whole computer for the price of an ssd like this? (with money left even sometimes).
    Totally crazy.
    Add to the fact that the performance is not on top of everything, seems like a pointless drive TBH.
Tags: Add Tags
