News OCZ opens new SSD plant
Discussion in 'Article Discussion' started by CardJoe, 27 Oct 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    All they need now is a product to compete with the C300!
  3. j4m3s10
    j4m3s10 What's a Dremel?
    27 Oct 2010
    Maybe the OCZ IBIS competes with it :0
  4. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    At least prices should be even more so on the way down :)
  5. Dudey109
    Dudey109 Minimodder
    20 May 2010
    Can only be a good thing!
    Costs are coming down!
  6. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    So when is Bindi getting the factory tour? ;)
  7. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    I will be backing seagates idea on the hybrid combined drive to be honest unless SSDs improve there ability to hold large amounts of data.
  8. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    I'd rather organise my own data
  9. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Prices down!! :D I want a 500Gb SSD for 200$ :p
  10. Burdman27911
    Burdman27911 What's a Dremel?
    26 Mar 2007
    Beat me to it.
  11. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    That's right Seagate, keep telling yourself that SSDs aren't worth bothering with while your competitors sell 140,000 units a month. And that's before they are £1 = 1GB.
  12. whiskers
    whiskers What's a Dremel?
    11 Dec 2009
    YES! Prices will go down, finally! Should we start buying up OCZ stock?
  13. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Yes
    No.
  14. WildThing
    WildThing Minimodder
    26 Jul 2007
    Me too, great minds...
    I wonder how far away this is from Bindi.
  15. Pete J
    Pete J Employed scum
    28 Sep 2009
    Woohoo!
    My dream of having entirely SSD storage in three to four years' time for my next rig comes closer to reality.
  16. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    Still not enough. SSDs are - unfortunately - a premium product, most of them is not compatible with RAID setups (and not talking here about 2 disks in RAID0 running on software/chipset configuration). Problems with TRIM, GC, lifespan under heavy load and various controllers (JMicron comes to mind). Price is still biggest stumbling block. For a one/two small SSDs it is not tragic, but even minimum storage around 1TB SSD cost absolute fortune. And if you want for example to run 16x2TB disks in RAID6/60, then SSD route is a complete no go.
    IBIS is interesting if you intend to run one such drive. If you want to RAID few of them you can't because IBIS architecture is already 'RAIDed' internally.
    Both routes (SSD/hybrid-HDD) are total dead ends. HDRs are probably way forward, but this technology is still some time into the future. h-HDDs just like hybrid cars are just ridiculous waste of money and materials. SSDs is of course very nice, but it won't survive too long. Certainly not as main storage solution. Prices won't drop too much for very simple reason. Every new generation of NAND Flash while faster is more and more expensive. So with every new generation of SSDs we will witness exactly the same crazy circle, as with previous SSDs.
  17. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Don't forget most people only need a small SSD (64-128GB) for the OS and most used apps. It's a waste to fill them with games and videos/music etc.
    I only have 2 games installed on mine and that's only because they have exceptionally long loading times. Most games only take a few seconds loading anyway off a normal drive to not need to fill my SSD. I'm still only using half the space on my 128GB SSD since buying it back in December.
    For most things the only benefit of an SSD is its silent compared to the wurring of a normal drive which unless you watercool you won't hear that over fans and GPU cooler anyway.
  18. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    YAY cheaper SSD's for all!
  19. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    Sf-1200 ones seem to have very good GC in them
    I find anything less then 128gb is to small (recommend 256gb or 2x segate xt drives as they work very well in raid for the price and do not need to worry about trim)
  20. LordPyrinc
    LordPyrinc Legomaniac
    7 Mar 2008
    Definitely looking forward to lower prices. I looked at SSDs last year before building this rig, but couldn't justify the price. The Raptors were expensive enough but still way cheaper than the equivalent storage size of the SSDs. I'm speculating that in about 3 years they'll reach the right size and price point. Hopefully sooner, but I'm a bit pessimistic (or realistic) by nature.
Tags: Add Tags
