News OCZ unveils PC2-9200 FlexXLC hybrid-cooled memory
Discussion in 'Article Discussion' started by Tim S, 21 Nov 2006.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DougEdey
    5 Jul 2005
    Whats the signal integrity like on current DDR modules? (Or any RAM for that matter)
    I know the principles behind data problems (did some for Principles of Computing) but is it a significant amount on existing modules?
  3. Tim S
    Tim S OG
    8 Nov 2001
    There's that unwritten bit of marketing in anything like this, but DDR2 speed increases have slowed considerably since the initial launch - a bit like the way that DDR got to 550MHz quite quickly, but then didn't go much further. With that said though, I don't think that any of the memory manufacturers would disclose signal integrity details outright, but if two have said that they need to improve cooling to increase speeds, I'd say that the problem is starting to become a problem.
    Implementation at 1100-1150MHz suggests that the problems will start to become apparent above 1200MHz.
  4. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    isn't this a little overkill? how much heat can these things make?
  5. DougEdey
    5 Jul 2005
    That would make a lot more sense, since the current drawn by a stick of RAM can't be a lot. so the only way for signal loss to become apparent would be by inducing current by high frequency.
    Micron lists their current draw as 3mA to 4mA
  6. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    PC's are turning into high powered cookers. The future brings 10k watt power supplies and desktop pc's with intergrated hobs and oven :p
  7. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    You'd be surprised, my Crucial Ballisitx are only slightly over-clocked and after an hour or so of gaming they are so hot you can't hold them for long.
  8. Sathy
    Sathy What's a Dremel?
    17 May 2005
    Anyone else notice that the "perfectly aligned fin design" won't exactly work all that perfect unless you have your motherboard lying flat - which won't happen in most cases (pun). And boy are they ugly!
  9. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    This seems to be gettin pretty nuts for water cooling. Quite a few people (the people who would buy this ram) will have 2 loops, one for gfx and one for CPU right? So now they would need a 3rd (for maximum effectiveness) to cool their ram?
    This is getting obscene (and obscenely expensive) don't you agree?
    Also, what kinda rig would require ram at this speed?
  10. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    yelids of ram chips that can run that fast are very poor so I wouldn't expect to see any much faster than this untill DDR3 or whatever is next.
  11. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    I have been waiting for RAM that has a sleek and smaller RAM block for water cooling.
  12. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    nice, I like this as an option for sure instead of having to buy like Ramplex for liquid cooling and its a nice combo with the heat fins. Hope to see more of this design or if anything hope that OCZ will offer a stand alone of this hybrid cooler to attach to existing memory ^^
Tags: Add Tags
