Storage OCZ vertex 2e
Discussion in 'Hardware' started by lil chris, 23 Jan 2011.
  1. lil chris
    lil chris What's a Dremel?
    19 May 2010
    Hi there I have just rebuilt my machine, is it worth swapping my vertex2 ssd to the new 6.0gb/s connectors on my motherboard. Will I gain any speed out of it over the 3.0 gb/s connector.
    I noticed in Custom pc when the test the drives they used a 6.0gb/s rocket controller card.
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    No you won't.
  3. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    The max read speed of your drive is 280 MB/s so having a faster connection than 3 Gb/s is not going to make any difference.
    I thought they only used the rocket cards for the Crucial C300 (6Gb/s) drive as the Vertex 2E is a 3Gb/s interface?
  4. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    in fact it 'should' be notably slower on the 6Gb/s disk controller for smaller r/ws - the ich9r/ich10r are the best controllers out there currently for 1 (or 2 in R0) 3Gb/s SSDs.
    Oh, & remember to SE the SSD before reinstalling using a method such as this...
    ...& that under-partitioning by ~21.5% (to increase over provisioning to the non-E versions) is your friend when it comes to maintaining speeds & longevity.
    Pete J likes this.
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    Exactly.
    I'd listen to PocketDemon- he seems to know more than any one man should about SSDs!
    PocketDemon likes this.
  6. PocketDemon
    3 Jul 2010
    i'm not quite sure whether that actually counts as a compliment or not...
    ...atm i'll pretend it is... ...& you're not really hinting that i need to get a life. ;)
  7. lil chris
    19 May 2010
    Thanks PocketDemon and all you guys. I managed to rebuild and with a bit of forward planning avoid a reinstall of windows 7,but that info for when I do a reinstall is worth knowing.
  8. lil chris
    19 May 2010
    by the way I'd take it as a compliment mate
  9. Pete J
    28 Sep 2009
    Ha ha! :D
  10. PocketDemon
    3 Jul 2010
    i did...
    Just was having a devil of a weekend & needed something to make myself smile... ...even if it was directly at my own expense. :)
