Windows odd codec problem
Discussion in 'Software' started by samuelellis, 20 Dec 2003.
  1. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    right i ahve a video file sat on my pc, when i try & run it media player goes off hunting for a codec then comes back with cannot downlad codec
    i tried using gspot to see what it is encoded with but it does not work properly with .mpg's & it wouldent render the file to give me more info
    any ideas?
  2. DeX
    DeX Mube Codder
    22 Jul 2002
    Try using virtual dub to open the file. You can use it to find out which video and audio codecs it requires. If it can't open it should give you some soft of helpful info on why not:
    http://www.virtualdub.org/
  3. samuelellis
    19 Apr 2002
    coes up with MPEG Import filter: Pack syncrination error
  4. DeX
    DeX Mube Codder
    22 Jul 2002
    In that case it's probably knackared. There might be a way to repair it but I've no idea how :p.
  5. ajack
    ajack rox
    17 Apr 2003
    This might help you out
