Odd question, DS in Black or White?
Discussion in 'Gaming' started by JinkzUK, 29 May 2007.
Black or White?
  1. Black
    24 vote(s)
    66.7%
  2. White
    12 vote(s)
    33.3%
  1. JinkzUK
    JinkzUK What's a Dremel?
    5 Jan 2004
    I can't decided and haven't really seen them together, which would you choose?
  2. Veles
    Veles DUR HUR
    18 Nov 2005
    Black is the most awesome, although you get fingerprints all over it.
  3. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Black gets finger printy and the white I believe suffers stains from skin oils specifically around the A/B/X/Y buttons.
    I like both though :D
  4. atanum141
    22 Jul 2004
    Black F T W.
  5. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    Get black. The brief period that I had mine last summer, it got all nasty between the DS and the clear plastic, nonremovable shell around the edges. It bothered the hell out of me. When I get a chance to buy another DS lite, I'll be picking up a black one.
  6. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    has to be black in my opinion!
  7. JinkzUK
    5 Jan 2004
    Cheers fellas!
  8. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Black is the best. Rumours suggest the weak hinge problem was more prone on the white and the black one just looks cooler anyway.
  9. DougEdey
    5 Jul 2005
    If you import from Australia you can get a light blue one.
  10. jeff127
    jeff127 What's a Dremel?
    21 Jul 2006
  11. Cabe
    Cabe What's a Dremel?
    14 May 2002
    Mine looks great in black, white is just so....ipod...
  12. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    White is more...pureist
    What't that you say? "post-purchase-justificarion-syndrome?"
    The black one wasn't available when I got mine :(
  13. Krikkit
    21 Jan 2003
    They're nicer than black imho - dunno how they wear, but it can't be worse than white!
  14. Mord
    Mord What's a Dremel?
    7 Mar 2004
    Speaking of which, is there any good way to restore white DS back to their white-then-white state? or it is just soap and water
  15. Krikkit
    21 Jan 2003
    Pretty much just soap and water I would think. You could try some Isopropyl alcohol, but it might blemish the plastic.
  16. riggs
    riggs ^_^
    22 Jul 2002
    It's ok, removes the stains quite well, but if you use it too much you'll lose the fine-textured finish. I don't bother any more...it's there to be played, not cleaned.
    But yeah, go for a black one...or hold on a little longer, and import a gloss silver one from Japan :hip:
  17. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
  18. Nexxo
    23 Oct 2001
    Pink? :p
  19. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    "honestly guys... i have a black one :worried: "
  20. Amon
    Amon inch-perfect
    1 Jun 2007
    White.
    If it were black, the idiot sitting across from you on the bus will think it's a PSP and annoy the sh*t out of you about it.
