Windows odd windows install issue ?
Discussion in 'Tech Support' started by stephen0205, 7 Dec 2021.
  1. stephen0205
    stephen0205 Minimodder
    11 Mar 2016
    Pretty sure ive done the first part, but i will give it another go in a little bit once i finish work :).
    I had done a clone before, but yeah, i can also pull the drive in the laptop and fire this one in to do an install, altho wouldnt it be easier just to insert the cloned one into the laptop, boot from it and do a reset ?
  2. stephen0205
    11 Mar 2016
    2 usb keys tried, one with rufus and one with the windows installer, both show up similar to this, i have enabled the os optimised defaults, and it has indeed disabled secure boot and legacy boot options.
    Now just getting a black screen regardless of what is happening, gonna use disk part to do a clean on the usb drive, and use the windows creation usb thing again see if maybe all the formatting and stuff has caused any issues
    EDIT: Same black screen with it done on a clean on disk part, but only the usb key option appeared this time with NTFS, still black screen tho
  3. stephen0205
    11 Mar 2016
    Ok so the plot thickens. By accident i left they mouse plugged into it, this was booted from the windows creator installer usb, i have a cursor somewhat..... So you see where the mouse is on the screen, if you were to make a square to the top left corner thats all i can see it within. Move to the right from where it is slightly and it dissapears. Move down, and it dissapears,
  4. Big Elf
    23 Apr 2009
    I had a similar problem with a NUC. I can't remember all the details other than I had to connect it to a full HD screen.
  5. stephen0205
    11 Mar 2016
    Sigh if only it was that easy, tried it through acer 1080 monitor, an lg ultrawide, and a 4k 55 inch tv, same problem
    this absolutely sucks
  6. sandys
    sandys Multimodder
    26 Mar 2006
    Check the iGPU memory settings and see if you can give it more RAM.
  7. yuusou
    yuusou Multimodder
    5 Nov 2006
    Try a different OS to see of its a hardware or driver issue.
  8. stephen0205
    11 Mar 2016
    Tried it with 512 and 1gb and nothing :(
    As mentioned in previous posts i have tried linux distros as well buddy, just does not want to boot.
    Tbh im getting ready to list it for spares. Might just keep the ssd and the ram
  9. ModSquid
    ModSquid Modder
    16 Apr 2011
    No, wait! Let's get this sorted as a flag standard for the Nu-Era - the bit-massive is still alive!
    Assuming you have the storage space for the next two weeks or so, especially given those seasonal presents need to be stashed somewhere...
    I was going to team up with @noizdaemon666 on this and either halvesies or charity drop, but that's doing a disservice - most of my tech solutions have come from tha noiz quarter so it's only fair the reward goes in that direction too. That said (I couldn't see from scanning, but might have missed), is SATA set to AHCI? Shouldn't be a huge issue but may play silly.
    If we get to the point where we're scraping, would buying an external DVD drive with a view to returning it after disc installation be a solution (assuming USB 2 sticks not available)? Or internal drive via temporary SATA connex (unless I've missed this having been done)?
    **** like this happens aaall the time to me - I have a KVM switch that I can flick between boxes and there are all sorts of inconsistencies introduced. I reset the "Local Nvidia Container" or similar and it seems to work itself out, but may need to re-do some settings in games.
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    What USB ports are available on it? Have you tried them all? Specifically not USB3?
    I MUST FIX ALL THE BROKEN THINGS!!1! :hehe:
  11. stephen0205
    11 Mar 2016
    Lol, those beers are a good incentive
    sata is set to ahci atm, but i have also tried the ide option to no avail. I also tried a dvd drive as i have an external one (since no moden laptop or pc has one and i still have cds). Couldnt get that to boot, used imgburn software to burn the dvd :(
    Lol i appreciate the enthusiasm , it has 5 usb 3 ports in total, and yes i have tried them all :), both with legacy and uefi
  12. ModSquid
    ModSquid Modder
    16 Apr 2011
    If I had a spare, I'd offer, but can you source/buy and return an internal DVD drive, just to bypass the USB and use the SATA connection?
  13. stephen0205
    11 Mar 2016
    I'll crack open the drive later see it it's SATA and hook it up to the internal data port just to see if it boots. But no way to attach 2, so if It did I wouldn't be able to install
  14. ModSquid
    ModSquid Modder
    16 Apr 2011
    I'm definitely clutching at straws here, but IF it did boot the Win disc from that DVD drive, could you use a PCI to SATA adapter to install onto the SSD?
  15. noizdaemon666
    15 Jun 2010
    I think the easiest solution might be to install the SSD in something else, run the install on that but turn it off after the first restart so it doesn't start the Out Of Box Experience where it installs drivers etc.
  16. stephen0205
    11 Mar 2016
    cool so plan, fire it in the laptop, let install when it gets to restarting system with the countdown, power off , pull the drive
    on lenovo just uefi on mode ?, and attempt to boot from drive ?
  17. stephen0205
    11 Mar 2016
    So hard drive in the alienware, done the diskpart clean on the drive, done the install to point of restart. Powered down, pulled the drive, was done with the windows creation tool on UEFI, fired in the lenovo and GUESS WHAT .
    . Yeah nothing, bios with the os optimized feature on and secure boot off and it boots to yet another blank screen
    Even with sata as the only boot option i get this when i ask for the startup device menu
    select it and blank
  18. ModSquid
    ModSquid Modder
    16 Apr 2011
    Jesus. This is a puzzle, no doubt...
    It's not something daft like memory? Have we checked that?
  19. stephen0205
    11 Mar 2016
    Nup the built in diagnosis option has a memory scanner, left it for the several hours it took to do a mem test, both sticks checked, out, and has been tried with 1 stick. Has been tried in each slot, with the 2 different sticks :(
  20. yuusou
    yuusou Multimodder
    5 Nov 2006
    Maybe put the storage on another computer with safeboot disabled, install the latest igpu drivers, then move the storage over to this system, also with safeboot disabled. Make sure you're in UEFI mode in the bios on both.
