Ode to Silence - Updated September 18
Discussion in 'Project Logs' started by fyes, 14 Apr 2005.
  1. fyes
    fyes What's a Dremel?
    25 Mar 2005
    I figure I'll test it as is, and if it isn't cooling to the level I want, I'll make a new one. I'm not going for any over clock records, I just want my machine to run silently.
    Anyway, I bought the copper block at onlinemetals.com
  2. fyes
    25 Mar 2005
    Hehe. Maybe at the end of the project I'll do a blooper real, so you can see all the attempts that didn't work before I finally got the one that did.
  3. morishani
    morishani What's a Dremel?
    29 May 2004
    Damn looks good for an home-made!
    Im subscribed :)
  4. Mondak
    Mondak What's a Dremel?
    27 Dec 2003
    Great work. Just shows that the more you do things the mover you learn. Reason is a wonderful thing.
  5. fyes
    25 Mar 2005
    Update June 16
    Thanks for all the encouragment everyone.
    Small update today -- almost finished with the chipset waterblock. Here are a few pics with milling finished, lots of filing, and a bit of 100 grit sanding done.
    Fairly close to the design, huh? Eat your heart out, G69T ! :D
    I would have drilled the holes for the fastening screws today, but wouldn't you know I've misplaced my small drill bits. :miffed:
    Next steps: build cover and solder the two pieces together.
  6. morishani
    29 May 2004
    Thats well done :) may-b sand it more so it would "mirror" effect?
  7. fyes
    25 Mar 2005
    Yeah, I'll do that after I've soldered the top and base together. Definitely want to get it nice and shiny.
  8. matrixops
    matrixops What's a Dremel?
    17 Feb 2005
    I've got to give you a :thumb: . That takes a lot of patience to do mill work on a drill press.
    Keep up the good work.
  9. barbz
    barbz What's a Dremel?
    31 Jan 2004
    tru, u did a good job, it makes me wanna do my own waterblocks. whats the next step? are you going to do the vga and PSU :p waterblocks now, or start messing with the case? looks really good, keep it up, still subscribed. :D
  10. Jipa
    5 Feb 2004
    That looks all OK to be homemade with simple tools! I wouldn't have done those as nicely so cheers :)
  11. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Gonna watch this protect, looking real good nice work without the table.
    Morgan.
  12. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Love the waterblocks. Now make some for the gpu :D:D
  13. fyes
    25 Mar 2005
    Update June 21
    I think I'm finished with the chipset waterblock!! :thumb:
    Tinning the base:
    And the cover:
    After lots of heat and pressure:
    A view from the top:
    After removing the excess from the cover plate:
    Looks like the seam is nice and tight between the cover and base:
    Another view, post filing:
    Lots of sanding and some Dremel buffing:
    Top side:
    Test fitting on the motherboard:
    Another view:
    Leak test!!! :eeek:
    Starting to look like something real:
    The really scary leak test:
    That's it for today. Next up -- finishing the CPU block!!
    Cheers.
  14. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    Wow I remember seeing this thread looong time ago. If there would be no pictures of your work in progress, just the first attempt on cpu block and the finished product, I would not believe that it is the same piece of copper. Great job!
  15. morishani
    29 May 2004
    Looks perfect for home made :)
    *Thumbs Up*
  16. Pistol
    Pistol Guest
    OMG that's sweet for homemade
  17. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Really nicely made block mate, i should get some copper, learn to solder then make some for my project! would be sweet!
    i like the passive idea! :D should work nicely
  18. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Gotta agree. Very nice homemade man.
  19. Gioz
    Gioz What's a Dremel?
    21 May 2005
    very good "Z" block for your chip.but now we want a cpu block ;)
  20. fyes
    25 Mar 2005
    Coming soon!
    :D
