Ode to Silence - Updated September 18
Discussion in 'Project Logs' started by fyes, 14 Apr 2005.
  1. Firefox90
    Firefox90 What's a Dremel?
    14 Jul 2005
    Any word on the use of the palm with palm orb? I am bummed I can't get mine to work consistently. I have had about 15-20 full system crashes and 2 times when it actually worked. It sucks the project stopped being supported. I just wish he would have perfected usb support. :duh:
  2. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    You might want to knuckle-down and buy either a jigsaw (with metal-specific blade) or a bandsaw if you plan to cut more metal.
    Anywho, fabulous work so far.
  3. fyes
    fyes What's a Dremel?
    25 Mar 2005
    Yeah, I finally broke down and went and bought a $40 Black & Decker jigsaw -- used it to cut the base of the radiator. MMMMmmmm... like a hot knife through butter. Also works well (different blade, of course) on 48oz copper sheet, without going dull half-way through!
    Thanks for the feedback!
  4. fyes
    25 Mar 2005
    Mine was working fine everytime. Had it running for about a week without any issues -- no hangs, no crashes. It's not currently plugged in, but I may work it back into this mod at a later stage.
  5. Firefox90
    14 Jul 2005
    You are using a USB cable right because that looked like a newer palm.
  6. fyes
    25 Mar 2005
    Yep.
