Windows OEMact Vista keys
Discussion in 'Software' started by mrbungle, 2 Jul 2009.
  1. mrbungle
    20 Sep 2004
    Acer one this.
    No system disc and restore partition is down the spout.
    Have a genuine oem disk and it wont take the key on the lappy.
    What is a OEMact key and does it mean i need a acer specific disc?
    Its so hard to stay legit sometimes :grr:
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    OEM disk for what brand? The disk has to be the exact one matching the OEM serial key. You cannot use a Dell OEM disk on an ACER computer for example, even if it installs ok.
    So yes, you need an ACER disk - probably not any old one so you may have to contact ACER for a new disk.
    That's why I hate restore partitions - why not just put it on disc!
    Oh, OEMACT stands for Original Equipment Manufacture Activation Control Technology - a way of assigning activation keys to specifiec builds by manufacturers. Pretty much the same as OEM but restricted to the manufacturer.
  3. mrbungle
    20 Sep 2004
    General OEM disk like you would get from scan/overclocker etc not branded to anyone.
    Have the dell version (I own a Inspiron 1720 and Dell give you the partition AND discs) but no Acer one to hand.
    This stinks, Acer want money for the Discs.
    Add to the fact that eventhough the spec of the lappy is great it runs like arse.
    Acer are so crap :grr:
  4. Ransoman
    Ransoman What's a Dremel?
    18 Jul 2008
    Acer are rubbish. 100% failure rate when we bought some in for our company (we trialed 3, all broke within 6 months). And the support line are appalling!
    But yes, you get Non branded OEM disks and Branded OEM disks. The label on the base of the laptop gives this away and no other branded disk will work with that product key.
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    if it lets you install without a key, do that. then ring MS during the activation process.
  6. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    OEM edition Vista can not be installed on more than one system. It's designed to go out to Manufacturers like Dell. They set up the rig, and go "here, have a windows DVD". the moment you buy a new PC, new Windows needs to be acquired as well... hence OEM being cheaper.
