Open Source Office free ware...?
Discussion in 'Software' started by jopers1986, 22 Nov 2009.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    hi,
    Just wondering what a good free ware version of office is and where i can get it from?
    Can't find my memory stick with office on it :wallbash:
    Thanks for the help
    Rich
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I think Open Office sould be fine. I wouldn't know though, i don't use any Office at all.
  3. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    +1 for OpenOffice. Completely free and able to read most Office formats (it doesn't, I think, read Office 2007 files - the ones with the x on the end of the extensions: .docx, .xlsx etc).
    Available to download from the Open Office website
  4. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    +1, OpenOffice is an excellent alternative. I think the latest version(s) can read Office 2007 files, but I'm not 100% sure.
  5. Geoff x
    Geoff x What's a Dremel?
    6 Sep 2009
    Definitely try Open Office. According to this it can open Microsoft Office 2007 files, but can't save them.
  6. GoodBytes
    20 Jan 2007
    OpenOffice if you want free.
  7. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  8. Helium Charcoal
    Helium Charcoal What's a Dremel?
    21 Nov 2009
    There are a couple freeware converters out there that convert freely between .doc and .docx formats. The conversion doesn't usually work 100%, but it should be good enough for everyday purposes.
    It's sort of a clumsy workaround, but it works.
  9. dave_c
    dave_c Minimodder
    31 Jul 2009
    open office is great and it CAN definitly read Office 07 stuff, the issue is when i open file which i have saved to an MSO format from open office the margins tend to be differant to how they are displayed on screen when opened with MSO, which is fne, provided your not e-mail a CV or the likes
