Case Mod - In Progress Official "John Hanlon Fund Raiser" PC Build (Thank you Mach!)
Discussion in 'Project Logs' started by mnpctech, 23 Feb 2012.
  1. jhanlon303
    7 Sep 2006
    I saw the pictures on FB with you out and about with family. You have no idea how much family means until they are all gone. My post was a banter between me and Cheaps. No reflection on you. Cheaps and I go WAY back. The boy built a waterblock for me with no electricity in the middle of a hurricane. Drill press by hand? Friendship.
    john
  2. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    Grills look awesome sorry for blurry pic but my camera should be on its way from the shop . ..
  3. DarthBeavis
    29 Aug 2008
    this is how i will mount the res but cannot do that until I have fittings
  4. rchiileea
    rchiileea Minimodder
    11 Jan 2008
    Glad to see the patriot stuff at last :) looking forward to more updates
  5. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate i see you holding it.
  6. Cheapskate
    13 May 2007
    Ouch. I see some 90's in your future... That res is gigantic!:D
  7. DarthBeavis
    29 Aug 2008
    yep got some BP rotaries here
    Gonna bolt the res to the HDD cage good thing I ship with Instapak . . .if that thing broke loose in shipping it would great so much damage it might take down the airplane in flight or make the UPS truck go off the road
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    I was wondering how the res would fit in thinking it would cover a good bit of the motherboard, just shift the gpu lower, of course. :D:duh:
    It is an awesome feature for the rig & would have definitely been a shame for it to be hidden.
  9. Plodder
    Plodder What's a Dremel?
    14 Apr 2012
    New members first post.
    I am so lucky to be a member of such a comunity, (a new super nooby member but still...). You are all such an inspiration for my modding and life in general.
    @John, I hope you are as well as you can be and though i have nothing material to offer, (very poor and struggling to pay bills atm sorry :sigh:), i send you my best wishes.
    Thx to you all. :thumb:
  10. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    What about fitting it in the HDD rack and it looking clean plus it'll have more support there ? My 2P thats all =0 Things are looking brilliant cant wait for this to go up , Ship to uk ? :p
  11. DarthBeavis
    29 Aug 2008
    Does not fit . . .
  12. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Wow, grills do look good in red :) Yea, i didnt pull the paper off so this is the first time seeing one other than the black test model.
  13. yougotkicked
    yougotkicked A.K.A. YGKtech
    3 Jan 2010
    I hate to be the bearer of bad news, but I don't think you should mount that graphics card in the secondary slot. Most 1155 boards will only give the second slot 8 PCI-E lanes whether or not the first slot is populated, I'm checking the documentation for the board you're using (GIGABYTE GA-P67X-UD3-B3 right?) and it seems to be the case with this one as well.
    Any way to mount it on the lower cage just above the floor radiator? could make wire management and tube routing a pain but it looks like it would fit.
  14. DarthBeavis
    29 Aug 2008
    Show me tests that indicate an appreciable difference between 8 and 16 ;)
    http://www.tomshardware.com/reviews/amd-crossfire-nvidia-sli-multi-gpu,2678-5.html
  15. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Yay! You chose the spot I suggested. Are you going to also create a bracket like the one I sketched for you? ;)
  16. DarthBeavis
    29 Aug 2008
    thinking about the bracket part . . .might just make a simpler one want to keep it mounted close the the drive cage
  17. yougotkicked
    3 Jan 2010
    Interesting, I hadn't seen an article on the topic before. As a computer science major I would not have thought the bandwidth was so unnecessary, if you cut the bandwidth of the RAM link in two, you see an immediate 50% performance loss. I'll be moving my graphics card now, it's blocking the airflow of 5 case fans because I assumed it needed to be in slot 1.
  18. DarthBeavis
    29 Aug 2008
    as a former software engineer I can tell you the bandwidth is not saturated :D When I am not modding I also work events for ASUS and NVIDIA so I try to keep up with details like this as I give a ton of advice out while on the road.
  19. yougotkicked
    3 Jan 2010
    It makes a lot of sense now that I think about it. I know that when they make new format standards they make sure there is enough room to grow (the latest gen of CF memory cards' firmware can address a petabyte-scale capacity), I just didn't really think about how much throughput each lane could deliver.
    :clap: HURRAY FOR LEARNING!! :clap:
  20. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    Its very touching to see an online community come together like this.
    I just wish that I had some hardware that I could give towards the build, unfortunately it all seems to be sorted out.
