Disaster Oh Rodney you dipstick!
Discussion in 'Modding' started by Cabe, 15 Jun 2002.
  1. Cabe
    Cabe What's a Dremel?
    14 May 2002
    OK, so I've had a bad day. I put too much pressure on my CPU fan lugs and snapped the centre mounting lug on the side without the flat bit. Does anyone know of any fairly light CPU HSF's that have the ability to attach to the offset lug?
  2. christiaanm
    christiaanm What's a Dremel?
    24 Feb 2002
    crap
    my answer, Ducktape !!!!!!!!!!!! you can use it for every little problem:p
  3. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    think the taisol range uses all three lugs, but i dunno how well it would work.
  4. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    yeah, I would go with the Taisol 760, it is light and will use your one remaining lug. I would worry about uneven pressure on the core a little bit, you may not get ideal cooling but you don't have many choices ... bummer
  5. banished
    banished Necromodder
    6 May 2002
    I would attach the heatsink from the taisol and use the fan holder for a zalman flower. --should cut down on weight/vibration.
  6. christiaanm
    24 Feb 2002
    what you could do, is , use an elastic put it between the heatsink an try it to attach to something, like does condesators, this could hold it,
  7. banished
    6 May 2002
    BTW, do you still have the piece that broke off?
  8. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    That's never a nice accident! hope it didn't break or short anything else! And please tell me the machine wasn't running when it happened!;)
  9. Cabe
    14 May 2002
    the board still works (thank our Lord Dremel) and the bit of plastic shot across the room, never to be seen again :(
  10. Scorpio170
    Scorpio170 What's a Dremel?
    21 Jun 2002
    :dude: JB Weld..the ultimate fixall..if ya find the plastic tab that is :cries:
  11. Cool Hand
    Cool Hand King of the park
    21 Nov 2001
    ya, i dont see any reason why you could not fix that with the right super glue....i have glued stuff together that size, that have held much more force than what the heatsink clamp will put on it....
    what you need is a good Cyanoacrylate glue....go with the thin stuff...the thicker stuff is easier to work with, but the thin will give you the best bond.......get it at your local/online hobby shop.
  12. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    who's rodney...lol
  13. Scorpio170
    21 Jun 2002
    sounds like an alias, so the real po hapless victim doesnt have to reveal his identity :worried:
  14. jamiesurfs
    21 Oct 2001
    Oh come on! Rodney, as in 'Only Fools and Horses'! It's just a catch phrase.
