Motors Oil filter woes
Discussion in 'General' started by Telkman, 29 Oct 2003.
  1. Telkman
    Telkman What's a Dremel?
    22 Apr 2002
    Today was oil service time for my fiesta - I emptied out the oil fine and then came to the oil filter.
    Its in a right awkward place which doesn't help, but its stuck fast. Can't get it off by hand or with a strap wrench. My plan is to smash a screwdriver through from one side to the other in the morning and use it as a lever to get it out.
    That is of course unless you fellas have any bright ideas on how to get it off...
    Telkman
  2. KinGvsKinG
    KinGvsKinG What's a Dremel?
    20 Apr 2003
    was the engine still hot? gotta let it cool. also, try using a belt, worked for me in the past.
  3. Telkman
    22 Apr 2002
    I'll try a belt, it might grip better than the strap wrench :)
  4. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    nowt wrong with the screwdriver method but i like my engine, open the bonnet & there the oil filter is, with tons of space around it :D
  5. Telkman
    22 Apr 2002
    I've changed the one on my mums car before - thats sat right at the front with masses of room, easy to do. Damn ford :(
  6. RaptorLord
    RaptorLord What's a Dremel?
    6 Aug 2002
    they make tools that go over the end of an oil filter (fits in the grooves and stuff on the end) that you can get a socket wrench into to take that out of there. I suggest you spend the 5-10 quid and pick one up..
  7. -Rx-
    -Rx- What's a Dremel?
    18 Dec 2002
    Use the screw driver.... much cheaper.
    The person that last put it on probably forgot to oil the rubber seal....
  8. Telkman
    22 Apr 2002
    All done now - the screwdriver worked a treat (if a little messily) thanks for the comments lads :)
  9. djrusty
    djrusty What's a Dremel?
    20 Aug 2003
    Good work fella - the screwdriver method is the one I always use - and I have a Mini - not a lot of room to work. Anyway, punching holes in stuff is much more fun than using proper tools!
    :rock:
  10. RaptorLord
    6 Aug 2002
    hacks! all hacks I say! :dremel:
  11. -Loay-
    -Loay- What's a Dremel?
    7 Jul 2003
    My dam oil filter is behind the engine, so the only way I can get to it is from underneath, and jacking a car up and sitting under it using a strap tool, caussing the car to shake and jolt aint fun :eeek: Dam Jap car's... just lucky my car's fast.. otherwise I would have gotton rid of it agges ago :p
    Loay.
  12. Telkman
    22 Apr 2002
    Mines at the back too - you can see it from above but theres not room for anything to fit through and get a grip on it.
    Hopefully I put enough oil on it for it to be easy to get off next time :rolleyes:
