Ok, I am a moron....Help me Please...
Discussion in 'Hardware' started by EMTABMM, 23 Feb 2005.
  1. EMTABMM
    EMTABMM What's a Dremel?
    23 Feb 2005
    I have an MSI nForce2 K7N2-V motherboard with a AMD Athlon xp2600+ 333mhz cpu. I decided to try and overclock it. Now all I get on bootup is a
    Award BootBlock BIOS v1.0
    Copyright (c) 2000, Award Software, Inc.
    BIOS ROM checksum error
    Detecting floppy drive A media...
    INSERT SYSTEM DISK AND PRESS ENTER_"
    It does not give me an option to hit delete to go in and reset anything. This was my first try at overclocking and may well be my last. Needless to say, "Mama is not happy." She would rather I had spent the $135.00 to get the xp3500. Help if you can.
    Thank you.
  2. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Mmkay...
    Turn the computer off and open the side panel. Remove the CMOS battery. Wait 20secs and put it back in. Reboot and see what happens.
    - H.
  3. [Tom]
    [Tom] Minimodder
    10 Dec 2003
    Have you tried resetting the CMOS? There should be a small jumper on the board to do this- check the manual.
    <edit> Beaten by Herbicide- removing the battery will do the same thing.
  4. captainanabolic
    captainanabolic Banned
    9 Feb 2005
    yes try this.but if the computer powered off during saving to cmos(after overclocking) then if that doesnt work you might need to download BIOS for the mobo(available at manufacturers website) at a friend's house then save it onto a floppy (thats why it is asking you to insert a floppy.
  5. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Yes. You'll need the bios .bin file and a copy of awdflash.exe on the floppy. Good luck ;)
  6. captainanabolic
    9 Feb 2005
    wow we agree on this one Kam. :p
  7. EMTABMM
    23 Feb 2005
    So reboot with floppy with aforementioned files, go in and return settings to "normal" and all will be well? or might be well? or will I be purchasing that new cpu after all?
  8. Kameleon
    29 Apr 2003
    It should be fine...I wouldn't advise getting that CPU, unless you typo'd - the only 3500+ CPUs are Socket 939 chips and probably wouldn't fit in your Socket 462 board that well :worried:
    Have you reset the CMOS yet?
  9. EMTABMM
    23 Feb 2005
    No, I am at work and the sick machine is at home. I thought it was a
    Socket A board?
  10. Kameleon
    29 Apr 2003
    Socket A = 462 pin. Every 3500+ processor = 939 pin. They would cost more than $135 though, so I think you probably didn't mean 3500+...
  11. EMTABMM
    23 Feb 2005
    Ya know, you are right. This is what I was looking at.
    AMD Athlon XP 3000+ "Barton", 400 FSB, 512K Cache Processor - OEM
    (limit 5 per customer)
    - Specifications -
    Model: AMD Athlon XP 3000+
    Core: Barton
    Operating Frequency: 2.1GHz
    FSB: 400MHz
    Cache: L1/64K+64K; L2/512K
    Voltage: 1.65V
    Process: 0.13Micron
    Socket: Socket A
    Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
    Packaging: OEM (Processor Only)
    Model#: AXDA3000DKV4E
    Item#: N82E16819103394
    Rating: Vote(s): 165 Review(s): 83
    $135.00
  12. captainanabolic
    9 Feb 2005
    yes should work.but if not it wont be the cpu, that will be fine. the worst case scenario is you fooked the motherboard's BIOS chip so a new one of them if was possible or a replacement motherboard at worst.
  13. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    if it restarted with it flashing then your bios will probably be screwed unless you have the gigabyte dual bios that automatically flashes it back to the original bios becuase it usually can't even get to the boot from screen when you mess up...
