Modding Ok need a quick mod idea :)
Discussion in 'Modding' started by malcs, 8 Jul 2003.
  1. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    im in the mood... the mood to mod!! anyone got an idea what i could do with this case?
    bearing in mind that i dont have the materials available atm to complete the window, and i need something to do with that floppy cant for the life of me think what i have covered up the old reset button using a BiT case badge :) whaaaaat can i do with that floppy drive?? something quick and easy lol i have millions of resistors, a few red LEDs, lots of fans, a nice little mobo connecting 2 usb port tho if i use that the USB 2 ports on the back of the PC do not work (the ones not directly connected to the mobo- beside the status light) could i move the status lights and USB 2 ports on that thing 2?
  2. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Hide it away.
    :p :lol:
    I still say straighten up those edges
    Tidy the cables away from view?
    Floppy drive... backlight it? So red glows inside. Couple of LEDs right in the back oughta do it?
  3. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Paint the chassis internally with some nice, shiny color.
  4. Dad
    Dad You talkin to me?
    15 Apr 2003
    1- Paint the inside gloss black & paint the bezel to match
    2- put some nice molding around the window
    3- sleeve the psu cables
    4- put a ducted blow-hole in the front
    5- take some sandpaper to the case to remove the paint it looks like you missed (esp the creases)
  5. malcs
    24 May 2003
    Good Idea!!! :D
    Where on earth can i get this from? not in a window kit?
    know where i can get the sleeving?
    Very good idea, i have a fan there anyway :D
    believe it or not that is actually the camera and what creases?? there are none on the real thing lol
    oh yeah here are two updated pics :) scuse the fingerprints on second one :s i forgot to wipe those off before taking the pic and then my cam dissapeared :(
    i think i will give it a little bit of a polish lol trust me thats not powdercoat residue
  6. mrplow
    5 Sep 2001
    6. Fix all those b0rked bold and quote tags.
  7. malcs
    24 May 2003
    Done And Done :D
  8. mrplow
    5 Sep 2001
    i think doing the front and inside black could look sweet...
    get the sides wet and let them rust :D :D
  9. malcs
    24 May 2003
    lol i dont want rust but the black idea is cool :D
  10. Dad
    15 Apr 2003
    Easy!
    Local auto parts store. You can get inexpensive door molding which will do the trick...
    Um, not unless you're in the US. If you are, I just bought a 25' spool for 17 bucks at Jameco.
    I mean like where the side panel and the top panel meet. To me it looks like there's still a bunch of paint in there :/
    Actually, I'm trying to do that with my current mod. There's a special paint kit / tecnique that will put a rust effect on a project.
  11. malcs
    24 May 2003
    ah those are the joins and the rounded edges of each panel are highly reflective, as i seemed to sand them most :s alas im in UK need to find a cable sleeving manufacturer
  12. AdeTBun
    AdeTBun What's a Dremel?
    18 Jun 2003
  13. burnoutuk
    burnoutuk What's a Dremel?
    18 Feb 2003
    Linky
    Some else told me about this earlier... looks very good I think/hope this is what your after?
    Love the front of the case :thumb:
  14. mrplow
    5 Sep 2001
    Or, don't spend stupid mod-shop prices.
    http://rswww.com/ sell sleeving. About a fiver for 5m I think. I'll ask Hippo
    edit:
    oooh colours
  15. malcs
    24 May 2003
    wow :) thanks guys :)
    EDIT:: ooh just what i need for that empty bay :)
  16. Supercool
    Supercool Gone.
    31 May 2003
    Did 2 PSU's for about £5 with the stuff from rs.
    Heatshrink £1.73 1.2m (170-6406)
    Braiding £2.72 5m (389-886)
    worked for me :thumb:
  17. malcs
    24 May 2003
    was looking for smd leds have found them :D :lol: :D :lol:
  18. pranks7er
    pranks7er mange tout
    25 Dec 2002
    remove the case front and use coloured plexi instead
  19. malcs
    24 May 2003
    yeah how would i go about getting the measurements etc for making my own bevel out of plexi or aluminium?
  20. fjr0122
    fjr0122 What's a Dremel?
    20 Dec 2002
    You could make it quieter by ducting the processor :)
    That's 33cent a sheet walmart craft foam stuff (it looks rough because black duct tape was the best thing i could find to join it together) . But it made my comp quiet enough to leave it on all the time. :)
