Graphics OK, so I'm a fool!
Discussion in 'Hardware' started by Herbicide, 17 Jun 2004.
  1. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Yesterday, I finally got round to installing a CD-Rewriter and, as usual, when I'm installing something, I dropped a screw into the case. I had to shake it about a little to find it, finally retrieved it, put everything back together and plugged it all in.
    I turn it on, and am greeted with the message: "Monitor OK, check PC and cable". :eyebrow:
    Everything else is working fine, PC passes POST and boots, so I shut down and unplug everything, when I get to the Graphics card, clunk! It falls to the bottom of the case! By now, I'm thinking this may be the problem, so I shove it back into the slot, secure the screw with Blu-tac, top and bottom (I think the previous owner had it secured with a standoff, so even case screws are too small). :wallbash:
    I get everything screwed and plugged in again, and I am greeted with the same message.
    So now I come to my question: How hard is it to kill a Graphics card? (GeForce 2 MX 400 64MB)
  2. Ds3
    Ds3 What's a Dremel?
    20 May 2004
    Hmm it shouldn't be that easy to kill… Are you 100% it's plugged in properly now and all relevant power cables etc are plugged in?
    Maybe the card just withered up and died from old age? Ever needed a bigger hint to upgrade? :p
  3. TMM
    TMM Modder
    12 Jan 2004
    hard to kill a GF2 tbh,those things are pretty in destructable :p i've got about 5 kicking around, still working :D
    does it work in another comp?
  4. Herbicide
    27 May 2004
    Ds3, I'm gonna check when I get back home.
    TMM, I'm checking that out tomorrow.
    If it is dead, I'm getting a GeForce 4 128 off a mate, see if I can haggle down to a tenner :D
  5. Ds3
    20 May 2004
    I meant a real upgrade :p Get your wallet out, dust the cobwebs off, and buy a 9800 Pro :D
  6. Herbicide
    27 May 2004
    Ignore the nonsencical extra words, if there are any.
    It works! all I did was take it out for a while (the length of the England-Switzerland game) and put it back in!
  7. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Personally, I think you should get a new video card anyway :D What do you do with that thing? Play Alien Versus Predator One and Unreal Tournament One as your primary 3D games at low resolutions? :D
  8. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Just get a new card. The 4000 series is getting a tad on the older side. If the card really is dead then don't nickel and dime it. Go all in and get a higher end video card.
  9. r3Q
    r3Q Minimodder
    31 Jul 2002
    haha you guys are funny! i got a Geforce2 Ultra 64mbDDR! and guess what? i get doom3 at a steady 12fps! PUNKS! was $300 when i bought it SUCKAS!
    lol. im waiting for the x800's... waste of time with a 9800. not even gonna waste my time with new hardware until 939\pci-e :hip:
  10. Herbicide
    27 May 2004
    I plays UT 2004 at normal, with decals and foliage, and some other things I can't remember off the top of my head.
    HALO was ok, but a bit harder on the GPU that UT, and I'll get around to trying that Doom 3 demo someday.
    As for upgrades, I'll see after the Summer Hols (damn near twelve weeks off!)
