Build Advice Old kit, new build, advice please
Discussion in 'Hardware' started by MrP, 12 Apr 2020.
  1. MrP
    MrP seeking inspiration
    5 Jul 2007
    I'm looking at upgrading some of my old rig.
    Current it's an i7-2600, 8GB ram, r280x and it's good enough, but I'm bored and fancy something newer.
    I have a few bits that I have bought over time that I want to use, a corsair carbide 400c case, coolermaster masterliquid lite 240aio, and a 512gb corsair mp500 m.2 as
    I'm fairly settled on a ryzen 5 3600cpu, and some corsair vengence rgb pro 3600 ram (bit ott maybe, but for once I want a little bling!)
    I'm torn on what board to use, I fancy x570 for future proofing and bling, but sense says b450, but either way I would like built in WIFI (for bluetooth). The gpu is staying for now (not ideal but I dont have the cash to upgrade that as well)
    Many only other concern is my psu its is/was a decent unit, a corsair hx620, but it's I dont know how old and I'm slightly worried that it may no longer be good enough when I want to oc thecpu.
    Any advice please, esp on the board psu.
    Many thanks
  2. Spanky
    Spanky Minimodder
    14 Apr 2010
  3. MrP
    5 Jul 2007
    Does the 3rd gen ryzen suffer with the memory issues when paired with b450?
    Was it the cpu or chipset that resolved those issues?
  4. spolsh
    spolsh Multimodder
    4 Feb 2012
    B450 with a Ryzen 3600 I've had working at 3600 C16 and 3200 C14 RAM ... never got over 2933 with the old 1700
  5. Vault-Tec
    30 Aug 2015
    It's CPU dependent IIRC. They've gotten better.
  6. adidan
    25 Mar 2009
    Yeah Ryzen 3000 has far less issues compatibility wise.
