Modding Old laptop LCD mod
Discussion in 'Modding' started by JPLocutus, 8 Jul 2003.
  1. JPLocutus
    JPLocutus What's a Dremel?
    16 Apr 2003
    Okay, before everyone jumps at me, I have used the search and have read nearly all of the posts regarding this issue.
    Anyway, every month I freqent a trade show of sorts called First Saturday (which is held, *gasp*, the first Saturday of every month), and people have an unbelievable amount of crap...good crap and bad crap, but most (if not all) used. For instance I just bought an old working Dell P133 (with everything included but the CDrom) for 5 whole bucks. Worth it for the spare parts alone. One guy in particular though had piles and piles of old (like P90 or P100) laptops that were not tested and for the most part not working. He was selling each for $15, so I thought it would be worth it to buy one and use the LCD (I didn't though). Through some searching on the 'net I've come to figure out that it is pretty pointless to attempt to use the LCD w/o a controller card. However, I have also heard that some laptops that have VGA input because they have a mini-pci card inside for video and input, so modding becomes much easier.
    My question is: has anyone ever heard of such a thing and if so, know which old POS laptops would have one?
    Btw, ZapWizard, if you read this, I know you tried to use an old vid card as a controller card, whatever was the outcome to that? Didn't work?
    Thanks all,
    -JP
  2. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    The simple answer is look at the laptop you're thinking of buying. If there's a HD 15 pin connection on the back (IE a monitor jack) you're onto a winner (just make sure it's a video in and not out).
    No, Zap couldn't get it to work.
  3. pranks7er
    pranks7er mange tout
    25 Dec 2002
    interesting doe sanyone know what age of laptop should have such a connector?
  4. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    I've never heard of an old laptop with a video in before.
  5. Iamgoodyy
    Iamgoodyy What's a Dremel?
    11 Nov 2001
    Edited- To refrain from looking dumb. Silly me, and my lack of reading skills.
  6. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    erm mebbe he said Output :D
  7. JPLocutus
    16 Apr 2003
    Nope, I meant input...but I was also reading that off someone's post in another forum, so THEY might have meant output :D
    Either way, I'll just have to take a look at the connectors on the laptops the guy has next month.
    -JP
  8. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    I very much doubt any of them will have VGA in.
  9. malcs
    24 May 2003
    if the LCD screen has its own controller, like my laptop's one u could use that :D
  10. pranks7er
    25 Dec 2002
    found this on ebay
    http://www.openlocal.co.uk/ebay/s1036c.jpg
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=3421842940&category=3712
    may this work
    also got this reply from a seller quote:
    Hi There
    I'm afraid I'm no expert in these terms, however, there is a 15-pin socket
    (female) on the back which initially looks about the size of a 9-pin com
    port but it is actually a tripple deck of 5 holes. Does this make sense???
    0 0 0 0 0
    0 0 0 0 0
    0 0 0 0 0
    Regards
  11. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    im interested... i have that exact screen(screen only, i jacked it from my school cause they had like 20 of 'em donated to them right before we got out, so i took a screen or two)...
  12. Clockworks999
    Clockworks999 What's a Dremel?
    20 Jun 2003
    I have never seen a laptop with VGA in. The VGA socket is for video out, so you can plug in a decent desktop monitor- would you want to work on a 9.5" screen?
    Cheers
  13. pranks7er
    25 Dec 2002
    use it in a mod thats what it could b used for eg a tv ,status thingy
