Electronics old lcd
Discussion in 'Modding' started by kobaj, 5 Jul 2004.
  1. kobaj
    kobaj Banned
    4 Jul 2004
    I have two lcds that i was about to through away when i decided someone has to know how to use them to show temp or time.one is an old samsong (model no.sgh-n105) cell phone. The other is out of an old printer (dont know the company or model no)that has the number on it AK66930-01.the cell phone is on top and the printer lcd is on the bottom
  2. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    your pics don't work - and they're bmps anyways.
  3. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    If one of them has a chip that say HD44780 on it there is hope.
  4. Skylined
    Skylined Minimodder
    3 May 2003
    HD44780 or compatible. ;)
  5. kobaj
    kobaj Banned
    4 Jul 2004
    that chip is on one of them(and i fixed the pics now there gifs) let me check the cell phone and see if it has one. oh ya i forgot i also found a third lcd while digging through my junk box ill check them both out and see if they have them
  6. feckless2k1
    feckless2k1 Minimodder
    2 Sep 2003
    You need to google for datasheets on each of the displays (using model numbers) If you find sheets and the displays are HD44780 compatible then just follow the LCD wiring guide in the electronics forum.
  7. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    pics still don't work :( (404)
  8. kobaj
    kobaj Banned
    4 Jul 2004
    well for one screw the pics,and two i went to google serched every number on all three devices and didnt find a thing
  9. kobaj
    kobaj Banned
    4 Jul 2004
    even if i had found the data sheat how would i be able to accualy show stuff on it (im new to lcds)
  10. feckless2k1
    2 Sep 2003
    Read the guide at the top of the page (its a sticky). LCD displays can be had really cheap, 16x2 ones can be found for $5/£4 nowadays, you need to wire them youself though. If your not sure what your doing I suggest going down that route - its not too hard and gives good results for a reasonable price.
  11. kobaj
    kobaj Banned
    4 Jul 2004
    what guide i see no guide
  12. Nigel
    Nigel What's a Dremel?
    7 Mar 2003
    Sorry mate, I think you'll find this thread drying up talking with that attitude. These guys are *really* trying to help. :miffed:
    They give you good advice. The HD44780 is an Hitachi control chip for LCD/VFDs (as far as I can tell). Very common on LCD displays these days.
    Let's be frank - if you can't see or don't understand what they're saying, leave the project alone.
    :blah:
  13. kobaj
    kobaj Banned
    4 Jul 2004
    i am very sorry to you all but i didnt realy know i was hurting enyones feelings, well mabye i should just leave this project alone. thanks to all enywase
