Mod of the Month Old Navy " COMPLETED " 30th September
Discussion in 'Project Logs' started by Canardwc, 27 Sep 2011.
  1. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Hi!
    I'm the author of a current scratch build called "Alumination" still in progress. In fact in hard Progress...!!
    But this week end, i bigan my first makable project, with all necessaries tools and materials..
    I've found 5 years ago in my father's room his old navy wallet... Aluminium wallet...
    At first, i used it as a pharmacy cupboard in my WC with one shelf. It was very easy to use everyday and really improbable and funny concept.. You'll probably tell me: " why not"?
    Two weeks ago, my girl freind needed a correct computer for her studies.
    Then I decided to gave her my old hardware configation:
    GA p35-dsr rev2.0.
    e6750 overcocked at 3,6 Ghz.
    8800 gts.
    Pretty old for a geek isn't it? But still working like a charm...
    Well, i combined the two olds stuffs PC&Navy Wallet..
    Another improbable combination.. You'll probably tell me for the second time: " why not"?
    So let's show you some... dust and durty work,
    [​IMG][/IMG][​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
  2. Canardwc
    22 Sep 2011
    So, I worked hard all night long and i waked up my neighbour at 4:00 pm... He wasn't really happy... :naughty:
    But This project progress by big step... Hope that continue like that...
    [​IMG][/IMG]
  3. Cheapskate
    13 May 2007
    Cool. :D
    Nothing says 'bomb' quite like a modified metal suitcase. Be careful how you transport it.
  4. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Looks dangerous :) definitely don't take it to any airports.
  5. Canardwc
    22 Sep 2011
    Thank you, a "cool" from you sounds great. I saw your sratch builds, you've got lots of amazing tools...
    So it's a good observation, because i exactly would like do it!!!
    Stupid, stupid I am.... :wallbash:
    lol
  6. Canardwc
    22 Sep 2011
    the objectif of this scratch buil is not to do a professionnal build, i want to keep the spirit of this Old Navy wallet.
    It's a "Punk" project, so do not expect amazing finitions... :p
  7. Canardwc
    22 Sep 2011
    I'll finish my project soon. I didn't took many pictures, because work is better than talk... and take pictures... :dremel: :clap:
  8. Canardwc
    22 Sep 2011
    Old Navy - FINISHED
    Job done!!! Hihaaaaaa!!!!!
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    Well, i done my first "Punk" scratch build. Use military wallet to unmilitarise it to do a common object like a personal computer...
  9. suenstar
    suenstar Collector of Things
    13 Sep 2009
    The very first image reminded me of a completely torn down Coolermaster Cosmos case that a friend did.
    Nice work with the mod, it turned out really well... pretty much the ultimate type of case for a LAN party. :thumb:
    How's the cooling and noise levels in that thing?
  10. Krikkit
    21 Jan 2003
    Great work, liking the scruffy exterior hiding useful interior.
  11. Canardwc
    22 Sep 2011
  12. Canardwc
    22 Sep 2011
    I've just sent the diagram airflow. There is only 1PSU, 1 fan, 1 stock cpu cooler and one 8800gts. It is pretty quite exept the old Sata HDD... :lol:
    REally thanks, a Punk Project...
    And thanks to your website, Amazing Community here!!!! :clap:
  13. Canardwc
    22 Sep 2011
    That will be my last post on this thread.
    Some good qualities pictures...
    IO shield from inside:
    On/OFF power button (homemade with old piece of caoutchouc):
    Point of view:
    Navy:
    The Punk rear of the beast:
  14. L1U
    L1U Minimodder
    1 Sep 2011
    weak spot in my opinion will be definitely the CPU temp, the airflow will more likely be somethink like:
    I may be wrong, but i think you better add an exhaust fan to the left of the CPU
  15. Canardwc
    22 Sep 2011
    Hi, your probably right for the fan on the side of the wallet but more i'll touch it, less that will looks like a wallet.
    Then, after 30minutes of OCCT, the maximum temperature rise to 65°C..
    The CPU is O/C with stock cooler, so I think it's "normal"...
