Case Mod - In Progress Olds Cool Lian Li V
Discussion in 'Project Logs' started by Colossous, 1 Sep 2011.
  1. Colossous
    Colossous Minimodder
    28 May 2007
    I've been off radar for a couple of years thanks to operations and illness type things but i've finally seen the back of that crap and today decided to Junk up an old Lian Li V1000. It looked a bit pretty allmost Mac G5 so i decided to spray it up in a Camo style i've done before to see what it looks like.
    Knowhere near finished yet but it looks kind of funky allready and i've got some more idea's for it including relicing it up before i transfer my i7 rig into it.
    Had to do the ancilliaries too - heres some of them -
    Side Panel.
    Beauty of this style is i can cut and mod it as needed and touch it up and the wear and tear that happens should add to the effect.
  2. L1U
    L1U Minimodder
    1 Sep 2011
    very nice painting, the final effect is just gorgeous :D
  3. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Awesome paint job. +sub
  4. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    I have the same case lying around. What kind of paint did you use ? Any special treatment before painting it ?
  5. David
    7 Apr 2009
    Intrigued.
    Subscribed!
    Teelzebub likes this.
  6. Colossous
    28 May 2007
    Thanks guys.
    I did another case a couple of years back using the same paint technique and there was more detail on the process here - http://forums.bit-tech.net/showthread.php?t=153767
    GhuilleAcoustic - i used basic car matt primer spray and i purposely did'nt prepare the surface as i want it to look a little rough around the edges and am thinking of ways to relic the paint as its a little too fresh looking at the moment. Reminds me of a Naval camoflage sort of effect so i may look for something along those lines.
    Teelzebub and GuilleAcoustic like this.
  7. GuilleAcoustic
    26 Nov 2010
    Thanks mate (+rep)
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Looking forward to seeing more updates Rich!
  9. Colossous
    28 May 2007
    Cheers Bill - i've been thinking up some more ideas after just kind of diving in with the paint hehe !
  10. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    sub'd
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice paint job urban cammo with style :D :clap:.
  12. Colossous
    28 May 2007
    Cheers guys :D
  13. Guest-56605
    Guest-56605 Guest
    Ninja'd
    Liking that paint job :thumb: :D
  14. Colossous
    28 May 2007
    Thanks 23RO_UK, day off tomorrow so more updates :idea:
  15. Colossous
    28 May 2007
    Today so far i've made a couple of panels to hide some wiring and ugly bits and sprayed them to match the design, i also took delivery of this lot :-
    New bits
    I made a stencil and sprayed the side panel, i wanted it to blend in but i'm not sure i like it ? I'm going to spend this evening ageing the case and parts so it might settle down and not be so obvious.
  16. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Great paintjob mate. How to?
  17. Colossous
    28 May 2007
  18. Colossous
    28 May 2007
    Running fine and installed - started to rough the case up a bit (spent 2 days dabbing in with stewed tea to discolour it - ended up with a brown hand lol !), a freind is coming to photograph it properley next week so i'll have to try some more tea lol !
  19. Colossous
    28 May 2007
    A freind came round today with his nice Dslr and so we have some final pics .
    And finally, a project for the winter ;-)
