Scratch Build – In Progress Omega Desk - [26 January] Project Complete!!
Discussion in 'Project Logs' started by Squigly, 20 May 2012.
Pump orientation, facing forward or facing backwards?
  1. Pumps facing backward
    15 vote(s)
    44.1%
  2. Pumps facing forward
    19 vote(s)
    55.9%
  1. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    Thanks gents!! Blade its actually a desk stand, the foot of the stand wont be used in final build though, you can see it here
  2. Squigly
    20 May 2012
    Ok so i was all *happy dance* about getting a major update done today.. Was expecting my parts back from the powder coaters, unfortunately due to some power outages they had had recently they were further behind that i thought.. so not even a single part was delivered back...
    So all I could really do was finish work on the screen stand mount, Since the intention was to use a 76mm diameter pipe for the central stand when i was planning my own screen cases. Now the problem was the central stand for this new system works off a 36mm pipe, much smaller than my original 76mm, and I didn't really want to throw that piece i had machined away..
    So this is how the stand is by default, I needed to remove the large foot piece to incorporate it into the previous stand
    And the stand that i had machined before, you can see the 3 grub screws i had put in that were to hold the original 76mm pipe, that flat pieces near the bottom slot between parts of the frame, and the bottom plate is bolted on to secure it to the frame.
    So what I ended up doing (as luckily I still had some material left over) was machining a piece with a 76mm OD and a 36mm ID :cool: I also added grub screw to that so i could secure this plug onto the main pipe and then use the original grub screws to secure the plug to the main stand... I also machined some other area's to make the two fit together nicely
    I also added a slot into the pipe for cables for monitors, keyboards etc to be routed into the main case
    Ok so these are the parts now for the main stand
    To illustrate, the plug secured to the pipe with 3 grub screws
    And the plug secured in the main stand
    So was happy i could at least find a solution to the new screen stand, I am also officially on leave until next year :shaky: so should the powder coating be completed i will be around in a flash to pick it all up!!!
    Thought I would also include some shots of the screen stand as it is by default, screens are set in landscape for now.
    I really like the arm system on this stand as it fits the desk theme pretty well (view from back)
    well.. thats about it then till i get the all important call...
  3. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    This monitor stand is awesome. What model is it?
    Edit: I'm an idiot. Thanks.
  4. l3p
    l3p www.^.nl
    1 Nov 2010
    Indeed a lovely stand!
    To bad they aren't available here in Holland :/ (I think)
  5. Squigly
    20 May 2012
    Thanks guys!! l3p im pretty sure you could get it there, as far as i know its not a local brand ;-)
    Right so no word from powder coating, but I did get a call from the nickle plating place :rock: was amped to pick them up, now they were all sealed and I only got a look at the waterblock plates and all seemed good.. anyways i got home and eagerly unwrapped the pipes.. at first glance it looked as if they had sanded the pipes even though i had polished them to a mirror finish.. was LESS than impressed.. :wallbash: anyways I got the buff out and just tried with the drill machine.. luckily they buff to a nice smooth finish so may have just been the coating process.. I am really hoping so.. will pop into the workshop 2morrow so i can buff them properly on the lathe..
    anyways here you can see the finish i got from them on the right and the pipe on the left i buffed a bit, must say the buffed pipe is looking rather yummy.. hopefully they all turn out nice and mirror..
    So anyways back to the block, as a reminder the block was originally copper and acetal as can be seen here
    the plates fresh back from nickle
    And mounted
    I really like the look now and will fit in so well with the build
    Will do an update 2morrow with the polished pipes...
  6. Sarakon
    Sarakon The German
    11 Feb 2011
    What building is that in the background. It looks so familiar, just can't quite place it.
    Other than that, the piping looks really good. Assembly time must come faster :D
  7. Squigly
    20 May 2012
    Tell me about it!!! Its apartments in Sandton, forget the name of them
    Ok so headed into the workshop to get the pipes properly buffed and to what they should be, As mentioned before i am using a lathe to assit me here, so have the buff in the chuck and then hod the pipes by hand, can get a little tricky and the pipes get SUPER hot, even with welding gloves on..
    Spent most of the day polishing the pipes, really wanted them to have a nice mirror finish, and after a full day of toasty hands, this is the result..
    A little closer :)
    Ahh but wait... what is that, that the pipes are resting on????
    yup, thats all the parts back from the powder coater on the dining table (da wife gave me a look for doing that :p ) Took a break today from polishing to walk over to the powder coater, they are across the street from the factory luckily just to check in to see how it was going, to be pleasantly surprised that it was all finished and I could collect :dance: unfortunately I had to leave the frame back at the workshop but arranged for it to be delivered tomorrow so i can build away over the weekend
    The_Gnu likes this.
  8. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Where/How did you get the block nickle plated? Was it copper before?
  9. mal
    mal What's a Dremel?
    20 Nov 2012
    Squig,
    When you get to it could you post how you bleed your system? I too am planning a desk type build, and am not looking forward to tipping such a large piece of furniture to remove air bubbles.
    Mal
  10. Squigly
    20 May 2012
    Yup i had them coated, they were copper before, I used a local company here that also did my copper pipes ;)
    Will do bud, I normally find the bubbles tend to sort themselves out after a day or so, but will be sure to post any "special" attempts I have at bleeding
    Ok so first of the final images, been a long time coming so just a few teasers for now :p
    more soon
    Squigs out :rock:
  11. l3p
    l3p www.^.nl
    1 Nov 2010
    Ohhhh boy .. Can't wait!
  12. The boy 4rm oz
    10 Apr 2008
    The plating on those pipes looks top notch :thumb:.
  13. dotdrew
    dotdrew What's a Dremel?
    29 Dec 2011
    The plating on those pipes looks fantastic after buffing, can't wait to see it all put together.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    The pipes polished up real nice :D:dremel::jawdrop: congrats & can't wait for the final shots. :D
  15. The_Crapman
    5 Dec 2011
    can't wait to see it all together. this wait is gonna be as bed a christmas eve!
  16. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Sweet buffing going on there.
    I have to say I'm a bit jealous at the moment, getting parts back from treatment is like christmas. Sharpen your screwdriver, fill up the fridge with beverage of choise and have a nice weekend of assemblying.
    Awsome project, and rep + for doing a desk with a pretty challenging shape.
  17. bluc
    bluc What's a Dremel?
    4 Apr 2012
    MOAR UPDATES. !! :D
    Sent from my Nexus 7 using Tapatalk 2
  18. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Cant wait to see those pipes installed they look awesome
  19. Squigly
    20 May 2012
    Thanks all, put a lot o work into em pipes so was real happy with how they came out...
    Ok so been busy with the build since last Friday, been a hectic few days but machine is finally back up and busy posting from it now, Alas the glass company let me down and didnt deliver yesterday (or today for that mater) so still not 100% done.. but lets start at the beginning shall we..
    So Friday of course I had all the pieces back from the powder coater, I needed a few more cables and to pick up all all important :mdpc: package (A big thanks Nils!!!)
    So started pretty late Friday afternoon, wont go step by step as there are over 150 images of the build alone ( a big thanks to my dearest wife for being my photographer during all of this) but started with mounting some panels
    could then start with a few components slowly but surely
    first of the rear tubing
    jumping ahead a bit now, got the mobo in, and all cards as well as most of the front tubing in
    then got busy with a few more panels
    time for that monster 1080 radiator, this is a shot of the little power distribution board i had made up before from some vero board
    and mounted on the panel
    Then in the desk
    of course MDPC is adding its special touches everywhere
    an innards photo of the two temp sensors and cd bay
    I also painted in the logo on the CPU block like i did the GPU blocks
    first drive mounted
    storage drives done
    back to finishing off the piping
    got the pumps mounted
    MAN DOWN!!!!! :p nope just busy connecting up some cables for the drives, but at this point it I was feeling like the desk was winning a bit
    Of course all cables were nicely sleeved, went with shrikless for all points, love this stuff!!
    more panels mounted...
    and finally last piece of the waterloop in, the flow meter.. was a happy momnet!
    got the top panels and screen mount prepped and installed
    ready for screens
    then got the cable routing panels covered
    After a slight snag where i need to get a 90 degree adaptor for one of the screen cables as its JUST to short, had to change the screen rotation for the moment, also got the front plexi and front panel mounted
    front UV leds mounted
    then it was crunch time... time to fill the loop and do a leak test, just one small leak in the back ares where my muppet self didnt tighten the one connector so an easy fix with minimal spill.... luckily!!
    after a 24hour leak test with pumps on full power i turned them down and was time t power it up, these are the temp sensors on the radiator btw..
    so this is it for the moment...
    Still to do:
    Phone and hound them to bring the glass (mount glass) lolz
    also need to mount the back panel and get the 90 degree adapter for the screens... and that's bout it!!!
    Will of course do a bunch of final shots when its all ready, as well as a vid of the LED breathing effect
    As always thanks for checking in peeps
    Suigs out... needs me a nice cold beer and some rest!!
    Sarakon and The_Crapman like this.
  20. The_Crapman
    5 Dec 2011
    Looking incredible already. Dam those glass people denying us the finished article!
