I found some relays that i could use for a class prodject and need help wiring them up , it is a miniature SPDT 5vdc relay and since it is so small there isnt any text on it to specify what wires go to what pins. i would appreciate any info about miniature relays and i have checked google and downloaded the spec sheat for this relay but it doesnt have a wiring diagram
that's very odd... that's usually the first place you go for pinouts. are you sure there's no markings on the relays themselves showing you how to do what?
http://www.europe.omron.com/Images/UK_en/216_18885.pdf Shows middle pair as coil and pair on one end as common.
