Modding one psu for two motherboards
Discussion in 'Modding' started by doryakov, 22 Jun 2007.
  1. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    how can i use one psu to power two motherboards ?
  2. capnPedro
    11 Apr 2007
    You can't. Just get a second PSU.
  3. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    With a soldering iron?
    H.B.
  4. doryakov
    8 Aug 2005
    i think about something with parallel connection . my opinion is the connect another cable to the 24pins by parallel connection .
  5. mattthegamer463
    26 Nov 2004
  6. doryakov
    8 Aug 2005
    has you a pentium 4 psu guide?
  7. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    P4 PSU's are the same as 24-pin psu's minus the 4 pins on the end. Look at some pictures online to see which side the 4 pins are added then take them off when you do your mod.
  8. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Just solder the ATX and "P4 connector" (square 12v connector) in parallel. just do this to all the wires EXCEPT the green and gray wire.
    Just be sure that the PSU is able to deliver enough power to power two boards.
    Oh, and only one of the motherboards will be able to turn on and off the computer. (the one with green and gray wires connected)
  9. doryakov
    8 Aug 2005
    i connected it in parallel and it turns the two motherboards . can i turn only one?
  10. MrP
    MrP seeking inspiration
    5 Jul 2007
    no, useing 1 psu for 2 motherboards means both have to power on together.
    i did this with a friend years ago for a seti project, we even went as far as buying atx connectors and making an extension cable in order to do it.
  11. Vice
    Vice What's a Dremel?
    7 Jul 2007
    You can. Why would you post something so definitive as "You can't" , when you don't know the right anwser? Why not post something like, "I'm not sure how, but it would be easier with 2 psu's?"
    Does no one remember this picture? :
    You can do it, but the "how" is the question.
    ~Vice
  12. ComputerKing
    8 Sep 2006
    woooot.. yay my 1000W PSU!!! I love it now after see that photo... Love it ;) yeah Enermax rock 4 Mobo in 1 PSU :clap: I love my PSU
    okay here how : you get same cable ( 24 pins and the 8 pin cables ) and connect them to the main PSU like make the main PSU double it's easy
    but the problem that you can blow the psu or mobo or your hardware like I did becaues the idiot cheap psu... it will not handle and make evey thing boom..
    any way it's like copy the cables.. mean get cheap PSU and cut the wires and connecet them to the right colors to the main PSU...
    okay good luck brother.... take care of your self.. don't for get the fuses and etc.. to keep your self alive that is a power
    I love enermax :rock:
  13. MrP
    5 Jul 2007
    one a mate made for me 7 or 8 years ago, was for a server case with 3 motherboards in (all duron 650's that sort of spec) and 2 psu's.
    it never got used in anger, but was tested
  14. ComputerKing
    8 Sep 2006
    :naughty:
    that's what I mean.. It works fine but need strong PSU
  15. doryakov
    8 Aug 2005
    the psu were turned the two motherboards. i will build two pc on one case . i want the smallest case for it , so one psu for one case will save place on the case .
  16. tech3312
    tech3312 Where's my dremel o.0
    1 Apr 2007
    It should work the only bad thing bout it is if you have to shutdown the computer of one mobo you have to shut the other mobo to cause the computer acts as a relay when i shut's down it also shut's down the PSU unless you got a schematics that can act similar to a relay but digitally then your screwed if you have found a way i'm all ears i have thought of the same question but i have no answer to that question yet
    before you do anything with electrical make sure you know how to wire them up do you won't waste any money on them =) my suggestion
  17. doryakov
    8 Aug 2005
    i try it on old psu and old motherboards and it works and i saw it on the screen that the two motherboards are working . i think about to put a switch on the + cable (the green) .
  18. ComputerKing
    8 Sep 2006
    yup it works.... this is good idea it will work.. put at the green wire a switch like psu one and when you want to turn off just press it ;)
    well done buddy.. make sure it's goos PSU :D take care :clap:
  19. doryakov
    8 Aug 2005
    thanks . now i am searching about 600w psu to this . any idea?
  20. ComputerKing
    8 Sep 2006
