Windows One question
Discussion in 'Gaming' started by StarLion45, 2 Jan 2010.
  1. StarLion45
    StarLion45 What's a Dremel?
    2 Jan 2010
    Hi everyone :)
    And happy happy new year .
    I have a question :
    How do I install "sniper elite in windows7 ???
    Thanks for all help
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Retail or Steam?
  3. StarLion45
    2 Jan 2010
    Thanks for the reply ,
    I have retail .
  4. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    i should guess:
    press eject button on dvd reader
    put sniper elite dvd in dvd reader
    press the eject button again
    wait untill the dvd spins up
    click 'install' on the menu*
    allow the program to run, when windows asks you.
    click 'next', or similar, where appropriate.
    type product code in, if necessairy
    wait until the game is installed
    play game by typing 'sniper elite' in the start menu search bar, and hitting enter.
    * if no menu pops up, browse the dvd until you find an executable named 'setup' or similar.
  5. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Thread titling like this should be punished by death.
    Okay, okay, I should be more constructive than that. StarLion, welcome to Bit-Tech! I heartily recommend reading the FAQ for posting advice.
  6. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Have you tried the usual straight forward way? Could you describe what the problem is, if there is one at all?
    Without knowing any details i'd say you could try running as administrator in compatibility mode.
  7. StarLion45
    2 Jan 2010
    Okidoki
    Sorry that I don't explain properly .
    I installed the Sniper elite : C:programfiles etc
    installation run fine , but suddently that D... Starforce showed up , so I can't play it any more , what do I do ?
  8. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Insert the original disc? That's what Starforce usually wants.
