Windows Online drive duplication software
Discussion in 'Software' started by Cthippo, 14 Mar 2017.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I bought a Samsung 256 GB SSD to replace the overfilled 60 GB drive in my desktop, but I'm having trouble finding a drive cloning tool that will work. I downloaded the Samsung clone tool, which I used on my laptop and worked great, but for some reason it will not see the empty drive as being a Samsung SSD. This may be because it is a Lenovo replacement part and so maybe it identifies as Lenovo instead of Samsung.
    I looked at the description for Clonezilla, but it cannot run from the disk being copied, so i would have to boot into a live CD or USB drive to run it, which i would rather not do if I can avoid it. Is there a free online drive cloning tool out there that you guys can recommend?
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Cthippo likes this.
  3. Cthippo
    7 Aug 2005
    That worked, though it was not without it's headaches. Have some rep!:thumb:
