Motors Online tyre ordering
Discussion in 'General' started by CrapBag, 12 Jan 2015.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I need a couple of tyres for my car and I favour Avon ZV3's as they have proven to be really hard wearing and improved the grip in the front end of my Vectra no end over budgets (I used to deliberately front wheel over steer round roundabouts in the wet just to prove a point on budgets).
    My usual tyre place wants £97 a tyre which is a big jump on the last time I purchased when I bought 2 Avons and a budget for the rear for £210.
    I have searched online and can get them for £68.19 each, a saving of £57.62, add on to that around £10 each for fitting it seems to be the way to go.
    Has anyone ordered tyres like this before?, are the tyre fitting companies okay with fitting tyres u bring yourself?
    Any advice would be gratefully appreciated.
  2. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    blackcircles.com i use these normally.
  3. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I've ordered tyres with mobile fitting before and it's worked out fine. I think it was tyresdirectUk we used that time.
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Yeah, it's commonplace these days. You can even get them delivered to home and turn up at a garage with them in the boot, they'll happily fit and balance them. I expect it'll work out cheaper to use the full online service though.
  5. legoman
    legoman breaker of things
    28 Feb 2010
    Got mine from black circles, partly because its local the tesco by me has a fitting shed, an that i got double club card points on them and a discount!
    Usually id use tyre leader though
  6. jinq-sea
    15 Oct 2012
    I have only ever used blackcircles, and I had my local garage to fit and balance for 12 quid each inclusive of the VAT. I thought the service from blackcircles was good, and I thought the price was keen.
  7. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Black circles are not a great deal cheaper then my local garage and if I have to add £12 per tyre fitting it's well over.
  8. Modsbywoz
    14 Oct 2009
    I used BlackCircles.com and used the fitted pricing and it worked out cheaper than the most popular places like Quick Fit.
  9. GTIgeneral
    GTIgeneral Minimodder
    31 Jul 2014
    I've never found black circles to be that cheap, ive just bought tyres from camskill, had myself some hankook ventus prime 2's £8 cheaper per tyre than black circles.
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Actually just checked the options and black circles price was fitted so that's £182 which is better than my local garage but still cheaper dearer than the site I was looking at. I'm wondering if they add Vat?
  11. andrew8200m
    andrew8200m Modder
    4 May 2009
    Lovetyres.com
    They price match too
  12. creative
    creative 500rwhp
    23 May 2014
    Ive used camskill and blackcircle when I lived in the UK years ago and never had a problem back then either
  13. sandys
    sandys Multimodder
    26 Mar 2006
    A number of tyre places around my way will no longer fit internet ordered tyres without an excessive charge (£15-20 a wheel) that ruins the savings/hassle trade off.
    I found this last year when trying to put winter tyres on.
    If you use online tyre places also hit a check box to use their associated tyre fitters, takes the pain out.
  14. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    When I live near you so that's useful to know.
  15. Shirty
    18 Apr 1982
    I have always found that my local indy tyre place (called Tyreland in case you were interested) offers substantially better prices than any online service, and have a selection to rival the best of them. If it's not in stock it can usually be sorted same day.
    All the while you get to enjoy service with a smile from the lads and a free cuppa.
  16. Atomic
    Atomic Gerwaff
    6 May 2002
    I last bought from camskill and then got my local garage to fit them.
    The young lad (apprentice I think) does tyres so labour is cheaper.
  17. Sp!
    Sp! Minimodder
    6 Dec 2002
    I used http://www.etyres.co.uk/ for some cheap tyres on my girlfriends Ka. They came and fitted them with in a day or two on the drive and were still a few quid cheaper than any of the local garages. (the tyres were dangerously bald so fitting them on the drive was a real life saver).
