What is the best product to use to buff up my case and make it really shiny without removing the original paint. I have a Cheiftec (same as antec) Matrix TX10-BD Black tower case(see pic)??
a cool airbrushing of a knight fighting a dragon on the side of the case. Or if that's not your thing, a girl with big boobs. with bloo leds for the nipples of course
-LOL- Now for your real answers plz. :rofl: Toric stop smoking that sh*t you found under freinds bed ok......
I don't want to remove the original paint just want to shine it up sanding it will scratch it or remove it??
read this article from the great linear on his website http://linear1.org/gm/archives/00000080.php you can skip the first part as its about painting the case. but the part about the galze and all is good readin.
Being that your case's front is black plastic and the sides are steel painted black you really can't "buff" it to shine it up. I'd recommend spraying the entire thing w/ a clear coat. You could shine up the steel parts of the case up by wheeling it out with rubbing compound and a high RPM wheel. Then wax or polish it. Be careful w/ the wheel though... they spin fast enough to take the paint off cars if you don't know what you're doing... be sure not to do too much in one spot.
