Electronics OpAmp advice
Discussion in 'Modding' started by BjD, 15 Mar 2004.
  1. BjD
    BjD What's a Dremel?
    10 Apr 2003
    I have a stereo VU meter, the old school analogue type with needles, and am trying to hook it up to my stereo. Found this circuit which looks like i'll do the job nicely :thumb: Problem is the opamp, Ive had a look through Rapid but cant see the CA3140, can anyone suggest a suitable alternative. Never played with MOSFET opamps before :blush: If theres a dual type as well thatd be even better, make the circuit a litle neater.
    Thanks
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Look under fet opamps, CA3140E, 82-0688. It's a very common one, Maplin & ESR also have it. CA3240E is the dual version, also at Rapid. :thumb:
  3. BjD
    10 Apr 2003
    hmm yeah i obviously didnt look hard enough :blush: Cheers
  4. biff
    biff What's a Dremel?
    8 Jan 2004
    The TL071 is a pretty common unit to and seems a little higher performance than the one spec'd...not that you need high performance for this circuit though.
