Something strange has happened to all the icons on the toolbars in OpenOffice, so they are nearly unrecognisable. As below: I've tried reinstalling but with no luck...
Its the ONLY area where the colours are messed up... Surely a graphics card problem would be more all-encompassing? And I'm AV scanning as I type...
Ok, apparently it's not the only area where this happens. The Creative utility that came with my sound card also has problems:
And so it all goes in circles. I'll try one last time to download them, and if not, I'll reinstall the older ones that ame with the CD...
*Sigh*... every time I think I'm getting pretty good at this whole knowing what to do thing... Someone comes along and ruins it How do I do that?
Is your graphic card overclocked? If so, try lowering the clocks... Is it overheating? Maybe a poor contact between heatsink and core/memory?
Well considering you had trouble instaling the nVidia drivers in the first place, i'd go along that route. When you downloaded the drivers originaly, did you try downloading them from the card manufacturers site rather than direct from nVidia? Sometimes manufacturers have to modify the drivers to work with their cards. To be honest, i'd try a format, at least that way we can find out if it is a software problem or a hardware problem. If its a software problem it will be fixed and if its a hardware problem then you can return the offending component.
