Open Source open source "paint" program
Discussion in 'Software' started by StudioRecorder, 16 Mar 2010.
  1. StudioRecorder
    StudioRecorder Mobo's need Fabo's for company!!!!!
    14 Jan 2010
    does anyone know of any good open source software that is like adobe's fireworks?:confused:
    ideally needs to be free.:D
    thanks,
    StudioRecorder
  2. gnutonian
    gnutonian What's a Dremel?
    6 Jan 2009
    Something from here?
  3. capnPedro
    11 Apr 2007
  4. Hg
    Hg The game known as life
    3 Aug 2007
  5. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Paint.NET is great, but its not really like Fireworks. Its based on Raster layers wherein the objects become pixels that you manipulate with the edit tools eg if you drop text, you can't reselect it with the text tool, you have to delete the text and add it again.
    Fireworks, the last time I used it anyway, was heavily Vector based and could do things such as this.
    Having said the above, I exclusively use Paint.NET and its an awesome program. They've also got re-editable text on their roadmap :thumb:
  6. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
  7. StudioRecorder
    14 Jan 2010
    thanks for all the replies - im not sure if i want vector or a raster layer program.
    all i need it for is to create a couple of logos, and i suggested something similar to fireworks as i use to use it all the time in school so got to know it (although it is way to expensive for me to buy for myself)
    so which program would be best?
    oh it has to be able to handle high resolutions.
  8. Zoon
    12 Mar 2001
    Logo implies text, and if that will be 99% of your usage, then you will quickly become frustrated without the re-editable text option. It does sound like The GIMP or Inkscape would be good for you, so try both and see how it goes.
    The GIMP is basically a free Photoshop, and if you've ever used that, there's an addon which renames and reorders all the menu items to be pretty much identical.
  9. StudioRecorder
    14 Jan 2010
    have just downloaded gimp and started to use it but when ever i use the vector line tool (where you click at each point you want and it joins them up with a line) the lines vanish when i change tool etc, how can i get them to stay?
