Windows Opening ISO images?
Discussion in 'Software' started by Solidus, 13 Feb 2007.
  1. Solidus
    Solidus Superhuman
    26 Dec 2005
    Anyone able to recommend me a good free program to open an ISO image file i have? I downloaded ISO buster but it turns out its no longer free! Doh!!
    Anyone able to help? :)
    Thanks in advance guys!
  2. DougEdey
    5 Jul 2005
    Winrar, assuming you just want to view and extract.
  3. MixWizard
    MixWizard What's a Dremel?
    16 Jan 2007
    if you are wanting to mount the image then use Daemon Tools
  4. Solidus
    Solidus Superhuman
    26 Dec 2005
    Winrar doesnt seem to work, it says the file is either damaged or corrupted but im almost definate its not :S
    It wouldnt read it correctly whereas ISO buster did but simply wouldnt extract it due to me not having the full version
    Any other programs? :S
    Daemon tools i dont want to use as im a noob with it, id just rather extract the files :S
  5. riggs
    riggs ^_^
    22 Jul 2002
    I'll stick my oar in and recommend Alcohol 120% as an alternative to Daemon Tools.
  6. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Or Alcohol 52%.
    I downloaded it as a trial, but it hasn't grumbled about payment yet. Does 120% behave the same way?
  7. specofdust
    specofdust Banned
    26 Feb 2005
    Daemon tools hardly requires expertise. However, if WinRAR says its corrupt it almost certainly is. I've opened hundreds of RAR's with winRAR and never encountered a single problem. An alternative is WinISO(IIRC) but I don't know if thats free or not anymore.
  8. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    You should be able to confirm whether the file is corrupted or not, with a dedicated ISO program such as MagicISO, PowerISO, or UltraISO (the one I use) :idea:
  9. Solidus
    Solidus Superhuman
    26 Dec 2005
    UltraISO worked! thx mate!
    Also the file wasnt corrupt, it was winrar acting up...wierd.
    Thx again guys, once again you all prove helpful :)
  10. Hazardous
    21 Jan 2004
    NP :cooldude: Glad you're sorted :thumb:
