Opening PSU
Discussion in 'Hardware' started by Nicolee, 8 Jul 2008.
  1. Nicolee
    Nicolee Kastom Youzer Title
    2 Jul 2008
    Hello i am thinking of modding my Philips DVD player and put my system into it .The biggest problem except space is the PSU that is HUGE! I opened it and i saw that everything is connected to a " card " or something like that if i take tha card and the cables which are REALLY small and just put them in the floor of the DVD player will there be a problem?(the case of the PSU is HUGE so what if i remove it and keep whats inside) If yes can i buy something or do something to prevent any ..unexpected and maybe deadly problems ?
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    No, don't do that.
  3. Krikkit
    21 Jan 2003
    Try buying a really thin PSU instead. I wouldn't advise stretching an ATX PSU out to fit - they need decent airflow for a start.
  4. Nicolee
    2 Jul 2008
    Do you have any idea where to find thin PSU ? not more than 500 watt
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Yea small media centre type cases usually have them.
  6. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Or a rack mount PSU.
  7. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Or shuttle PSUs are small...
    RwD
  8. Asulc
    Asulc Minimodder
    18 Jul 2007
    So correct me if I am wrong, it sounds like you are advising against using a power supply without the coverings, just the parts? I don't see why that would be a big problem if good airflow was provided...
  9. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Because you don't want any 230V shocks in yourself or the components...
    Also it voids the warranty.
  10. Asulc
    Asulc Minimodder
    18 Jul 2007
    How would the 230V shocks hit the components without the case? Would they jump? Cause if they travel on the cables, they would do the same with the case on...
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    They don't need to jump. People put their fingers in and touch the live bits. I guess you just don't understand "Safety". It's not designed to safeguard someone who knows the set-up, it's designed to safeguard a stranger to the equipment - who could be your wife or child.
  12. Asulc
    Asulc Minimodder
    18 Jul 2007
    Nobody touches my computer but me. If they do, the computer is off and the psu is unplugged.
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Then feel free to kill yourself. ;) But don't recommend how you carry on as safe for others.
  14. Nicolee
    2 Jul 2008
    Is there any material that can protect the PSU and me from death? like a tyre or something like that ?
  15. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    Was already posted, but buy yourself a shuttle PSU - they are tiny and good. (and quiet too.)
    One of the reasons for that BIG metal box around the transformers, regulators, and caps (and heatsinks) is that they put out a LOT of heat. If you didn't have them in a big metal box with lots of air flowing through it, it could easily melt a hole through your dvd player and burn the table underneath. That burning and melting also starts to melt insulation on the wires attached to it. what happens next is ugly... (I've seen what happens to a power supply after the fan dies. My dad's computer kept getting "louder and louder - it was really annoying" But then one day the problem just "fixed itself" - he loved how quiet it was. Then, smoke and popping noises started to come out of the back of the computer.... I told my dad that he should have called me when the noise started... but anyway...)
    The other reason for the big metal box is safety as was already mentioned. There's a lot of power running through those things and the capacitors can maintain a charge even after the machine is powered off and unplugged.
    in conclusion - buy a shuttle power supply....
  16. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    If you mounted it on rubber and made sure that no stray wires or fingers can get near it, even when its off, the Caps in power supplies can hold a charge for a while.
    Just be very careful and leave the PSU for a day or two unplugged for it to discharge. Also connect a fan to the PSU and jump start it to get the last of the juice out.
    Also you could build a new enclosure for the psu that is thinner. But again, if you do something wrong it can be dangerous.
    We take no responsibility for anything that may go wrong, we advise against it.
  17. Nicolee
    2 Jul 2008
    well i decided to make the PSU external i will paint it black to match the rest Thank you all for your time .
